asus K52JR not starting. need 4MB bios rom
  • tedy58
    • Jul 2021
    • 7
    #41
    Re: asus K52JR not starting. need 4MB bios rom
    Hi the model is K52JcAS.
    After bios upgrade to 206 and NB not started.
    Here I attach the BIOS read from the MB.
    I read it with RT809H programmer.
    I would appreciate if get some help too.
    Thanks in advance!
    The world is small, but enough, isn't it?
      • 20405
      Thanks in advance!
      Post a picture of the white/green barcode sticker on the ram slot .
      • tedy58
        • Jul 2021
        • 7
        #43
        Here it is.
        The green sticker:
        PN:60-NZIMB1200-A04 K52JC (0206A) 10675279
        PT:N0AS1033MBB0142566 69N0IHM12A04
        The wite one:
        20CF304600CE - I suppose this is the MAC address I find it two times in the dump
        By the way the bad BIOS version that was trying to load is ver.212
        • tedy58
          • Jul 2021
          • 7
          #44
          Finally I found the solution in one other thread in the forum.
          Thanks to 'peste' in this thread
          it is for MB Rev. 2.1, but works ok.
          Then try this dump.
          After flashing no overheating the CPU.
          Only MAC address was not recognized by windows and show "!" to the driver.
          Just use method and tool in post#29 by khaahk and all went well.
          to add MAC address 20-FE-30-F9-AD-C4 to bios
          create DOS bootable USB stick and copy the BT.EXE to it
          boot from the stick (or boot clean DOS by some windows bootable disk) and execute commands:
          bt.exe -C CNFG /W C2 20
          bt.exe -C CNFG /W C3 FE
          bt.exe -C CNFG /W C4 30
          bt.exe -C CNFG /W C5 F9
          bt.exe -C CNFG /W C6 AD
          bt.exe -C CNFG /W C7 C4
          bt.exe -C CNFG /W D7 20
          bt.exe -C CNFG /W D8 FE
          bt.exe -C CNFG /W D9 30
          bt.exe -C CNFG /W DA F9
          bt.exe -C CNFG /W DB AD
          bt.exe -C CNFG /W DC C4
          or write a bat file to save typing in dos.
          use your machine's mac address of course.
          After all goes well just flash BIOS in standard way to any version you want.
          Thanks to all that work on that issue.
          • jerro77
            • Aug 2023
            • Hungary
            #45
            Hello Guys,
            Thank you very much I read through the whole thread and it made a brekthrough with my Asus K52JR Rev 2.2 motherboard. When I got the machine it turn on with full fan speed and a full black screen, but after flashed the BIOS with the first shared *.ROM https://www.badcaps.net/forum/showpo...20&postcount=4
            It started working immediately.
            Despite of that, couple of issues still existing for me too. Based on Sensors all the temperatures are good, but for some reason the ACPI shows ~90Celsius which invalid, and due to that the fan is on full speed all the time. (Already tried with different Fan, issue is the same)
            Also after the BIOS flashing I think the MAC Address also modified from the original . Now Ethernet port not functioning
            If that possible, could you please help me to create a proper dump for my machine what I can try?
            I'm sharing the original dump (I dont know that was correct at all, machine wont worked with it.)
            Also sharing the barcode from the MAC if it can help.
            Thank you very much for your help in advance
            If any further info needs, please let know.
            Appreciated in advance
            • hoaca388
              Badcaps
              • Jan 2022
              • 11344
              • Viet Nam
              #46
              Originally posted by jerro77
              Hello Guys,
              Asus K52Jr
              • jerro77
                • Aug 2023
                • Hungary
                #47
                Thank you very much! Appreciated for the prompt response and help.
                I'll give it a try and getting back to you
                • jerro77
                  • Aug 2023
                  • Hungary
                  #48
                  Thank you very much! All sorted! Now working like a charm.
                  Appreciated for the prompt response and help!
                  Have a good day ahead!
                  • giuseppe palazzo
                    • Mar 2025
                    • 5
                    • italia
                    #49
                    good evening I'm new to the forum I have an asus k52j and I tried your bios but with none of these parts I would like your help and possible​
                    • peste
                      • 12290
                      • ROMANIA
                      #50
                      post S/N, full name and model, motherboard model,etc.
                      post the contents of the bios chip even if it is corrupted..
                      • giuseppe palazzo
                        • Mar 2025
                        • 5
                        • italia
                        #51
                        good morning Here I am posting everything I have unfortunately they brought me the PC like this thank you very much in advance
                        • peste
                          peste commented
                          Editing a comment
                          Don't post pictures unless asked....write with the keyboard..
                      • giuseppe palazzo
                        • Mar 2025
                        • 5
                        • italia
                        #52
                        good morning ok the s/n is MODEL: K52J MB Ver.: K52JT ID: 1A ABNOBC0071XE478 K52JT-SX047X Check Number: 6353 WARRANTY: 24M <GA> MFD/製造日期/制造日期: 2010-11 the motherboard is 4K52JR MAIN BOARD REV. 2.3A
                        thank you very much for a good evening
                        • peste
                          • 12290
                          • ROMANIA
                          #53
                          the posted bios is corrupt...
                          The bios chip must be unsoldered from the board before writing or reading..
                          do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                          solder wires between the programmer and the bios chip..
                          here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                          • giuseppe palazzo
                            • Mar 2025
                            • 5
                            • italia
                            #54
                            good evening I could also try to remove the chip from the motherboard K52JR MAIN BOARD REV. 2.3A but I have deleted and rewritten the clip several times I don't know if it works
                              • 20405
                              Post a picture of the green barcode sticker on the ram slot
                              • giuseppe palazzo
                                • Mar 2025
                                • 5
                                • italia
                                #56
                                good morning forum unfortunately on my motherboard there are no green stickers but the barcode on a white sticker now I'll post it have a good day and thank you very much in advance
                                • peste
                                  • 12290
                                  • ROMANIA
                                  #57
                                  try post #14..
                                  https://www.badcaps.net/forum/troubl...mp#post1815004
                                  • razor_amd
                                    by razor_amd
                                    12-15-2020, 07:07 PM
                                  • throwaway327
                                    by throwaway327
                                    Model No: RC72LA
                                    Serial No: SBNVKD001014459
                                    06-18-2025, 05:52 PM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • lrouw84
                                    Asus vivobook s510ua bios changed to x510un
                                    by lrouw84
                                    Hi there,
                                    I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                    I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                    01-28-2023, 01:31 PM
                                  • DynaxSC
                                    by DynaxSC
                                    06-14-2024, 03:49 PM
