Sony VPCEB1E0E (PCG-71312M) BIOS
  • KEVSPIT
    • Sep 2015
    • 62
    • Malta
    Hi
    I have a Sony Vaio VPCEB1E0E (PCG-71312M) with a strange issue.
    The laptop turns on and start loading but after about 20 seconds the fan starts spinning as full speed and then it shuts off. It even shuts off when the HDD is removed and left for 20 seconds in the BIOS setup.
    I already replaced the BD82HM55 SLGZS chip but issue persists.
    Reflashed BIOS from online dumps did not help either.
    Any clues please?
    BIOS info:
    BIOS version: R0300Y8
    EC version: K0300Y8
    ME version: 6.0.3.1195
    Motherboard info:
    Motherboard: MBX-223 M960 (1P-009CJ01-6011)
    Chipset: BD82HM55 SLGZS
    EC: Nuvoton NPCE783LA0DX
  • KEVSPIT
    • Sep 2015
    • 62
    • Malta
    Re: Sony VPCEB1E0E (PCG-71312M)
    Update - Programmed the Flash with a dump found online and now it powers and DOES NOT shut off after a few seconds.
    However the fan control is intermittent. Sometimes it does not spin at all (even at very high temp) and sometimes goes full speed.
    When the fan is off the PWM signal is low on the EC and when on the signal is 5v.
    Any clues? Maybe the EC is faulty?
    • dj_ricoh
      • 2073
      can you attach the bios file here?
      • KEVSPIT
        • Sep 2015
        • 62
        • Malta
        Yes sure, please see below:
        https://dl.dropboxusercontent.com/u/...pc-ea%20eb.rar
        • KEVSPIT
          • Sep 2015
          • 62
          • Malta
          Update: Success!
          It took me 3 days non stop to fix this issue. It was software related after all.
          After changing a BD82HM55 chip, then the BIOS (dump) needs to be modified with a CLEAN ME firmware.
          I used Flash Image Tool: 6.0.40.1212 to inject the CLEAN ME firmware to my original dump.
          After several attempts it worked.
          Please follow link below to download the modified and working firmware. Please note that this is only suitable for Sony VAIO VPC EA/EB series.
          If you have the same issue on another platform, I will then provide more details on how to do it.
          https://dl.dropboxusercontent.com/u/...mage_clean.bin
          • bicalov
            • Nov 2014
            • 294
            • Netherlands
            I have read your thread and unfortunately, the link is outdated.(logical). I have the same issue with a vceb2s1e. The only way to get the fan quit, is to use afuwinx64 in a dos window. Until you restart the laptop and it will be on full speed again. You can't keep flashing every time.
            This indicates that it is something with the bios, but I tried many different versions and the next time it starts up, the fan is at full speed again. Strange.
            I would appreciate some help.
            thx
            • KEVSPIT
              • Sep 2015
              • 62
              • Malta
              Please use this one:
              • bicalov
                • Nov 2014
                • 294
                • Netherlands
                Thanks a lot.
                Sorry I want to be sure how to flash this file, pls advise
                • KEVSPIT
                  • Sep 2015
                  • 62
                  • Malta
                  Originally posted by bicalov
                  Thanks a lot.
                  I use an SPI EEPROM programmer. It can be done through command line as well but not sure how.
                  Can anyone help please? Thanks
                  • bicalov
                    • Nov 2014
                    • 294
                    • Netherlands
                    I tried different ways with Afuwin and FWupdate but no luck.
                    I do have the CH341A programmer, but I used that already on other eeproms
                    and that didn't go well. The programming in reading and writing went normal, the chip was recognized but the chip didn't work anymore after that. I flashed the wrong bios.bin or I did something wrong with the CH341A
                    • bicalov
                      • Nov 2014
                      • 294
                      • Netherlands
                      "Solved" the fan problem. I have been busy with Aduwin, Fwupdate, ME flash tools and tried them with different bios version. I have a combo now from R0300Y8 with K0230Y8 and I know this is not correct, but it works. Therefor the "solved" Enough time went in this fan problem.
                      Kevspit, thanks for the help and advise.
                      • igino
                        • Mar 2013
                        • 6
                        • Trnava
                        to bicalov:
                        hello, how you reach, bios and EC version is difference?i have fan problem too. thanx for you advice.
                        • ojuaraph
                          • Apr 2017
                          • ceara
                          i can download file please
                          • welhim
                            • Feb 2013
                            • 40
                            • philippines
                            hi can you please re upload the clean bin for this model we have same problem
                              • 20367
                              Try these, Flash bios and 8 pin EC.
                              • rockinho
                                • Mar 2014
                                • 13
                                • Argentina
                                Thanks bother this dumps working perfect
                                • coelectron
                                  • Mar 2014
                                  • 57
                                  • Argentina
                                  thanks bro.
                                  • vishalcomputers
                                    • Jan 2020
                                    • india
                                    Re: Sony VPCEB1E0E (PCG-71312M) BIOS
                                    any one have this model bios vpceb46fg
                                    • Vesko356
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • zenius
                                      by zenius
                                      12-08-2024, 06:13 AM
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
                                    • Bloodhoundje
                                      HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                      by Bloodhoundje
                                      I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                      I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                      After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                      I have desoldered the bios chip (GigaDevice...
                                      03-16-2024, 03:12 PM
