does anyone has X551CA Bios dump ? laptop power gets to the first mosfet then nothing
  • techman1025
    • Jun 2014
    • 497
    Re: does anyone has X551CA Bios dump ? laptop power gets to the first mosfet then not
    Hi Yup your bios wasn't empty and what i did was merge with the newest update 100% working file ..i think you need a new programmer and don't use the clip ..i use the tl866a for years all day long and is cheap on ebay with the opt sockets around 100 usa dollers .. you could always pull up the data sheets for you serial chip to compare ...if you where from n.j i would program and new chip for you.
    techman1025
    • techman1025
      • Jun 2014
      • 497
      Thanks highpulse for the feedback!!!cheers
      Techman1025
      • techman1025
        • Jun 2014
        • 497
        Hi One last thing one way of knowing if bios is working or not ...plug a external keyboard or mouse see if it light up is one way NEXTED ...IS are you getting RSMRST3.3V & S5 3.3V YESSS THEN YOUR BIOS IS WORKING ....If you use a donor bios with out rebuilding the me region on intel platforms ....you will have random reboots ...fans running full speed ..this is all caused by dirty me region ...amd is fine it could be use from another same computer with no problem ....just need you use a dmi tool to re enter that computer info serial,mac, and so on .
        Techman1025
        • Blacktek
          • Nov 2014
          • 250
          oh man, i erased it a couple of times already now i cant load the .bin file you sent me, keeps giving me errors
          • sreeni
            • Jun 2014
            • 4
            • India
            Asus X551CA laptop not powering after removing bios to copy the file. Now if i try to turn on, there is no power from battery nor adapter.But when i try to power on from battery, the battery charging ic (JC FB) is getting over-heated,but not from adapter.So please help me...
            • LP_tekh
              • Oct 2015
              • 95
              • Laos
              #26
              Is it working, the laptop?
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                #27
                techman your bios saved my computer , alltough , im gonna add you here my bios , since its win8 , and password must be enbeeded in te bios , and also to fix regions if possible :P
                ORI is my original bios
                the outher bios is the one you created Robert"techman"
                so if you can help me out i apreciate
                thk in advance
                • Nasir Raja
                  • Mar 2014
                  • 21
                  • United Kingdom
                  #28
                  Try this it might help this is from working ASUS X551M hope this helps. This is 8192 KB file if you send me the motherboard number or send me old DUMP i will try to help you. Thanks
                  • omerim41
                    • Apr 2014
                    • 4
                    • turkey
                    #29
                    hi friend i have same problem. pls try this;
                    RT8239BGQW RT8239B RT8239 product jc code (JC=CF,JC=ED,JC=IC,JC...)
                    • bekirsalman
                      • Nov 2016
                      • 137
                      • turkey
                      #30
                      thanks bro
                      Electronicman
                      • ravenmx
                        • May 2018
                        • 169
                        • puebla
                        #31
                        Originally posted by bekirsalman
                        thanks bro
                        thansyou this bios is ok
                        • karem adil
                          • Oct 2016
                          • 37
                          • alex
                          #32
                          100%
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • Citymin
                            by Citymin
                            S/N : 5RNK9FFT70...
                            Yesterday, 05:12 AM
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
                          • MDSI
                            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                            by MDSI
                            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                            Details:
                            Model : HP OMEN 17-an012nf
                            Motherboard Part Number : DAG3BAMBAF0 REV : F
                            Serial Number (S/N) : 5CD7280D51
                            BIOS chip : Winbond W25Q64VSIQ
                            Programmer : EZP2023+
                            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                            I already...
                            07-28-2025, 07:11 AM
                          • grimacelord
                            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                            by grimacelord
                            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                            Motherboard model number: DA0PAMB46A1 REV: A
                            Secondary motherboard model number: 0PAB
                            SKU: 685K4UA
                            Serial number is: 5CD3223BJP
                            Recently reflashed this laptop with latest BIOS and once...
                            05-07-2024, 08:06 AM
