Need Bios Asus S500C dump attached
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Need bios s500c. i attached original dump
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Need Bios Asus S500C dump attached
    try this
    Im Back... sort of...
    • gcomputers
      • Apr 2013
      • 509
      • Albania
      solved Thanks ala borbe i just solved with this bios
      • staicugabi
        • Feb 2017
        • 11
        • Romania
        The BIOS works just fine. Thank you!
        • dabyd64
          • May 2013
          • 27
          • spain
          Originally posted by ala_borbe
          try this
          Thanks!! Worked like a charm.
          The S400C bios also worked, but the keyboard layout was totally wrong.
          I had a stuck "Asus" boot screen, it didn't enter the bios or made anything else, resetting the cmos did nothing... flashed this and bingo!
          • Pascal Komlassan
            • Jan 2017
            • 806
            • TOGO
            good
            • Oleh2605
              • Sep 2020
              • 5
              • Italia
              Thank you!
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • f-bone
                Asus K513E no image, bios dump attached
                by f-bone
                Hi guys!
                I have this laptop which is turning on but has no image. I have attached the bios dump but I can't seem to find a working one. I also read a similar thread mentioning WBT.exe v314 but no instructions on how to use that.
                Can you please help me with a working binary that includes the DMI info from my dump? Or kick me to the right direction to try and add the DMI section myself? I used HxD on my dump and found the serial on multiple places so I am not sure what to copy.
                thank you very much in advance!
                br,
                george...
                07-04-2023, 02:27 AM
