Asus K55VJ Bios Dump Please..
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    Hi guys i need Bios dump for my asus laptop model K55vj intel i7 proc.
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Asus K55VJ Bios Dump Please..
    i doubt you will find it else, but you can read and post old bios here, i might help you
    Im Back... sort of...
    • alihomee
      • Dec 2012
      • 1582
      • malaysia
      try this
      • ridamouh159
        • Nov 2014
        • 365
        • maroc
        http://www.gulfup.com/?coy4Cm
        http://www.up-00.com/?MuNB
        • jeffwae
          • Oct 2014
          • 10
          • Indonesia
          i need it too.. thx for sending thats bios
          • Direncan
            • Mar 2019
            • Turkey
            Can someone reupload k55vj bios. I have k55vj laptop on k55vm rev 2.3 mainboard with gt635m. I tried many bios but gt635m still not working
            • Nomi929
              • Apr 2019
              • 5
              • Pakistan
              Hi, Can i get Ec.Bin file for Asus X555LD Rev 2.0.
              Plz Help.
              • Maste
                • Jun 2020
                • Turkey
                Originally posted by direncan
                can someone reupload k55vj bios. I have k55vj laptop on k55vm rev 2.3 mainboard with gt635m. I tried many bios but gt635m still not working
                +1
                • mike15
                  • Oct 2021
                  • CZ
                  Originally posted by alihomee
                  try this
                  Flashed this bios on Asus K55VJ and it works fine.
                  • mike15
                    • Oct 2021
                    • CZ
                    But Nvidia graphics was not working ... Attached is correct bios which works all good.
                    • fahri01
                      • Dec 2013
                      • Türkiye
                      thankyou.....
                      • Rr Rr
                        • Nov 2024
                        • 6
                        • Oman
                        How to replace K55VJ over k55VM?
                        I have k55VM in my laptop!
                          • 21583
                          Post a picture of the green barcode sticker on the RAM slot, if there is one
                          • Rr Rr
                            • Nov 2024
                            • 6
                            • Oman
                              • 21583
                              Not that, i asked you to post the barcode sticker https://www.badcaps.net/forum/troubl...or_amd?t=96604
                              • Rr Rr
                                • Nov 2024
                                • 6
                                • Oman
                                Is it this one?
                                  • 21583
                                  Is it this one?
                                  Is there a barcode sticker on the RAM slot, yes or no.
                                  • Rr Rr
                                    • Nov 2024
                                    • 6
                                    • Oman
                                      • 21583
                                      Wrong again....... .If you don`t know where the RAM slot is or what a barcode sticker looks like i can`t help you. Why do you want to flash the bios anyway, the laptop is running isn`t it, what`s the problem.
                                      • Rr Rr
                                        • Nov 2024
                                        • 6
                                        • Oman
                                        I can't find what you looking for🫣🤦🏻‍♂️
                                        I have problem wit my graphic card
                                        I have nvidia 635m but it is not working
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • kodox
                                          Asus ExpertBook B1400CB Bios Dump Needed
                                          by kodox
                                          need original bios dump, original bios has flashed by other technician before me.
                                          attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                                          unit info:
                                          Model: Asus ExpertBook B1400CBA-0711A1235U
                                          S/N: R6NXNZ006657238
                                          CN: 7F6F
                                          Mainboard Code: B1500CBA R2.1...
                                          08-16-2025, 12:20 PM
