Asus K55VJ Bios Dump Please..
  • Rr Rr
    • Nov 2024
    • 6
    • Oman
    Originally posted by SMDFlea
    Wrong again....... .If you don`t know where the RAM slot is or what a barcode sticker looks like i can`t help you. Why do you want to flash the bios anyway, the laptop is running isn`t it, what`s the problem.
    My laptop should have K55VJ but it's k55VM now!
    I need way to change it? ​
      • 21583
      Originally posted by Rr Rr
      I can't find what you looking for🫣🤦🏻♂️
      I have problem wit my graphic card
      I have nvidia 635m but it is not working
      You mean you flashed the wrong bios to it ? .The bios version that the laptop should have is the model that is on the barcode sticker on the RAM slot. Do you have an SPI bios programmer, yes/no ?
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • kodox
        Asus ExpertBook B1400CB Bios Dump Needed
        by kodox
        need original bios dump, original bios has flashed by other technician before me.
        attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
        unit info:
        Model: Asus ExpertBook B1400CBA-0711A1235U
        S/N: R6NXNZ006657238
        CN: 7F6F
        Mainboard Code: B1500CBA R2.1...
        08-16-2025, 12:20 PM
