Macbook pro A1278 820-2565
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    hi,
    i need bios dump for :Macbook pro A1278 820-2565
    EMC No:2554
    BIOS CHIP:MX25L6406E
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: Macbook pro A1278 820-2565
    thanks, i found it:
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      tnx for sharing it with us, might be useful one day
      • polytek
        • Dec 2013
        • 496
        • TUNISIA
        not at all, friend
        • casaba
          • Apr 2014
          • 25
          • morokko
          thanks
          • italiasimo
            • Sep 2014
            • 13
            • morroco
            Thanksssss
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              just saved one with this firmware.THANKS!
              • thisko
                • Apr 2016
                • Korea
                thank you!!!
                • elaouari
                  • Aug 2016
                  • 5
                  • algeria
                  merciiiiiiiiiii
                  • dahlia
                    • Nov 2016
                    • thailand
                    thank you sir.
                    • bodtech
                      • Mar 2016
                      • 9
                      • turkey
                      i need a1278 (820-2565-a) 2010 emc no 2554 bios ic 25Q64A pls
                      • Francisamd1
                        • Jul 2016
                        • 38
                        • Philippines
                        good day
                        any one have working dump
                        file a1278 820-2565-a?
                        i realy need working one.
                        Thank you
                        • raajkumar
                          • Mar 2015
                          • 354
                          • Srilanka
                          Originally posted by Francisamd1
                          good day
                          Thank you
                          You can try this following file. I got this for A1278 820-2565-A but my macbook pro is not booting. Because its having SMC Problem.
                          • Francisamd1
                            • Jul 2016
                            • 38
                            • Philippines
                            thank you but my file is only 4mb
                            • raajkumar
                              • Mar 2015
                              • 354
                              • Srilanka
                              you take a backup of your old bios and use this file to flash it.
                              • Francisamd1
                                • Jul 2016
                                • 38
                                • Philippines
                                i already do that the file is to large
                                • raajkumar
                                  • Mar 2015
                                  • 354
                                  • Srilanka
                                  what CPU used it ? is it Core i5 ? otherwise you don't try this. Because this Bios Dump for EMC-2555.
                                  • Francisamd1
                                    • Jul 2016
                                    • 38
                                    • Philippines
                                    its core 2 duo and the emc 2326
                                    • drmak
                                      • Jun 2017
                                      • 3
                                      • St Vincent
                                      Hi I need bios dump for 820 2565 - A EMC No: 2351
                                      • sharingan972
                                        • Oct 2017
                                        • 4
                                        • France
                                        Hello every body
                                        i try to dum bios to remove password whitout success , and i restored the original dump but the macbook won't boot now.
                                        I checked the chip, it's seem ok.
                                        Who can help me please, i'm in the deep sheet
                                        this is my original config
                                        MacBook Pro 13 pouces, mi-2012
                                        MB: 820-2565-A
                                        EMC : 2554
                                        EFI chip : mx 25L6406E (8pin)
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          Yesterday, 07:11 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
                                        • DynaxSC
                                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                          by DynaxSC
                                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                          11-06-2022, 05:22 PM
