Toshiba L50-A-158 corrupted bios
  • tiebone
    • Oct 2010
    • 17
    • Croatia
    Thanks to toshibas fabulous bios update software i now have a bricked Toshiba L50-A-158, and I just repaired the PoS. After the atempted bios update to 1.9v the laptop is absolutely dead....When I try to open the bios image that i dumped from the laptop in UEFItool it says "invalid data cheksum". If someone knows how to repair the bios image, I would be very thankful. Or if someone has a link to a website that has a guide on how to do it, that would work too. The bios is EC+Bios combination. Thx
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Toshiba L50-A-158 corrupted bios
    TOSHIBA SATELLITE L50-A-158 PSKK6E VG10S
    try this pls
    Im Back... sort of...
    • tiebone
      • Oct 2010
      • 17
      • Croatia
      The bios image is not working, sadly....Any other ideas?
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        is there any other eeprom on board? in flash there is ME_FW but not placed in main bios
        im confused :/
        otherwise it should work
        • tiebone
          • Oct 2010
          • 17
          • Croatia
          There is a second 2mb flash with the ME_fw but this firmware should not inhibit any and all response from the EC.
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            ok, that is what i thought
            so ec bios must be inside main... well i think that this is only fixable with dump from working laptop, but i do not have it
            we can try to update ME_FW in second flash if you post dump here
            they may be related
            • tiebone
              • Oct 2010
              • 17
              • Croatia
              Here is the ME_FW flash dump , take a look...
              I will try to get the main dump from a working laptop...
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                good luck
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  can you confirm me the motherboard model? it seems that there are two boards in this mode (L50-A-158)
                  i may given you wrong bios...
                  • hbissou
                    • Mar 2015
                    • 11
                    • morocco
                    what is the motherboard munber ?
                    • tiebone
                      • Oct 2010
                      • 17
                      • Croatia
                      It is the VGSG MB rev 2.1 with the i7 processor and the GTX 740m graphics (pskk6e-011006s4)
                      model number: H000053270 69N0C3M33B15
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        its so much easier when you have info
                        Toshiba Satellite L50-A-19N VGSG
                        dump from working bios
                        both eproms
                        • tiebone
                          • Oct 2010
                          • 17
                          • Croatia
                          After flashing both of the BIOS flashes with the obove provided dump, the toshiba is working again...Thank You ALA BORBE!
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            np, im glad to help
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1490
                              • portugal
                              ala_borbe as usual your mighty bios always help ejjeje
                              • tsakimak
                                • Oct 2012
                                • 5
                                • Greece
                                I already send a private message with the above to tiebone but i am posting it here also in case somebody can help
                                Hello,my name is makis from greece.I am facing a similar problem as you had with a toshiba satellite L50-A-1D5
                                PSKK6E-03V05LGE with i7 cpu.
                                I took the update to win 10 and everything was working ok for a week.Suddenly one day i powered on and after the toshiba logo it asks me the hdd code (i had it enabled) and after that black screen.
                                I dont know if it made a bios update, but now i cant enter to bios with no way.I tried all the combinations,took batteries out,used combinations with fn,used another hdd nothing.I really believe it is the bios otherwise why it wont let me enter to bios.???
                                Could you please tell me how did you reflash the bios?i am not completely a noob.I would be gratefull if you help me.
                                Best wishes for a happy new year.
                                • goback
                                  • Jan 2016
                                  • 4
                                  • Greece
                                  UNBELIEVABLE...!!!
                                  I am George from Thessaloniki + Greece (same city and country) and i have the same problem exactly in the same laptop (Toshiba L50-A-1D5 http://www.toshiba.co.il/en/disconti...ite-l50-a-1d5/), after my update in Windows 10 in 20 days later...
                                  And the unbelievable for me, because i use also hdd password + fast boot in Windows 10 before !!
                                  tsakimak as i read in other place, i think we should try these steps
                                  Prepare an USB Stick Dos Formatted Fat32 and copy this file into then follow this Recovery Procedure : (I think called bios Recovery file but don't know where i can find it..)
                                  - Performing the emergency flash:
                                  - Shutdown the netbook (notebook)
                                  - Remove all peripheral devices
                                  - Remove battery, Remove AC power cord
                                  - Press and hold the power button for 10 seconds (battery and AC power still out), then release
                                  - Put the USB Memory Stick in the USB port
                                  - Hold "Fn" + "Esc" and plug the AC power cord in
                                  - Now press the power button (whilst still holding Fn + Esc).
                                  Wait until the fan will run, then release "Fn" + "Esc" keys
                                  - The fan will run for about 2-10 minutes and the USB drive activity LED will blink
                                  - I think the netbook rebooted automatically. If it doesn't, unplug the AC power cord once the fan has turned off
                                  The bios should be updated with the modified or recovery BIOS, and boot as per normal.
                                  In this way You are writing back your original Bios You posted here and check if Recovery Mode is working on your laptop !
                                  If someone could help me and Maki..
                                  I will wish God bless him !!!
                                  Also i had update the bios version from 1.60 to 1.90 before 1 month in my lapTop, but for one month was ok in all functions !!
                                  Also i had read there https://www.badcaps.net/forum/showthread.php?t=49502 but if someone could help us and tell us something about steps we should follow, I will appreciate him so much !!!
                                  Thanks a lot & happy new year !!
                                  • goback
                                    • Jan 2016
                                    • 4
                                    • Greece
                                    (Sorry Mr.Mods for my 2nd post together )
                                    Please delete it.
                                    Last edited by goback; 01-07-2016, 11:47 AM. Reason: Was wrong with my keyboards and my mouse
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1490
                                      • portugal
                                      goback , usually our reflash is made with external programmer , we do unsolder bios and insert in a eeprom flasher to flash the bios with the files we do want .
                                      the overall problem here , is that you told many things , but (maybe its because its morning and still bit sleepy , but what is the problem ??? what do you want us to help you out ?
                                      • goback
                                        • Jan 2016
                                        • 4
                                        • Greece
                                        Thank a lot members highpulse and ala_borbe for helping me.. Now i understand what should to do exactly with eeprom programer and put out and back again the chip on motherboard..
                                        THANKS A LOT !!
                                        Your assistance was very useful & happy new year with my best wishes !!
                                        • FalconPunch
                                          Surface Pro X 1876 Bios corrupted
                                          by FalconPunch
                                          Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                                          Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                                          08-09-2025, 03:56 AM
                                        • zlr8r
                                          Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                          by zlr8r
                                          Greetings
                                          I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                          Serial Number: 5CG3202C16
                                          Product #/SKU: 739P0AV
                                          CT Number: PRTUE00WBI30YX
                                          Description: HP ZBook Firefly 14 inch G10
                                          BuildID: 23WWWGAZ602#SABU#DABU
                                          Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                          MAC address not found.
                                          • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                          10-28-2025, 01:56 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • sndestroy
                                          Toshiba Satellite P55-A5104SL - corrupted BIOS
                                          by sndestroy
                                          Hello all
                                          Model - Satellite P55-A5104SL
                                          Mainboard - VGSG MB Ver:2.1
                                          All flashing done w/CH341 adapter & EEPROM chips off board.
                                          PROBLEM:
                                          After updating from BIOS 1.70 to 1.90, it shows Toshiba logo and halts. I narrowed it down to a possibly corrupted BIOS. How do I know? There is no similar machine in the forums, so I tried a dump for another model with same mainboard (L50-A-19N) provided by @ala_borbe in this thread. Flashed this on both BIOS & ME_FW chips and the laptop came to life again! BUT, with these symptoms:
                                          05-09-2021, 12:20 AM
                                        • TylerHyde21
                                          Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                                          by TylerHyde21
                                          Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                                          I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                                          I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                                          This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                                          06-29-2024, 10:38 AM
