Dell 15r 7520(5520) bios dump needed
  • tiebone
    • Oct 2010
    • 17
    • Croatia
    Hi, im working on a broken Dell 15r 7520 laptop and I am in a need for a pch and ec bios dump. The bios recovery system is not functional. The PCH bios consists of two bios chips (2 mb and 4mb). The bios from a 15R 5520 is the same but only if the laptop is equipped with the Ati graphics chip 216-0834065 ( radeon 7730M). If anybody can dump these from a working laptop, I would be very grateful. Thx
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Dell 15r 7520(5520) bios dump needed
    pls post motherboard markings, and also would be useful if you post bios and ec dumps
    Im Back... sort of...
    • tiebone
      • Oct 2010
      • 17
      • Croatia
      The motherboard is a LA-8241P , Rev:1.0(A00) with the 216-0834065 graphics chip
      I can not post the bios dump since that is what I need...or I misunderstood You...
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        you should backup your nonworking bios first
        i got raw file from update from website
        if you dump non working bios from eeprom maybe i can rebuild bios... done it before, not on dell but all uefi bioses should be same/similar
        edit:here is dump from 5520, no mine, found elsewhere
        dump of 2mb file seem to be empty, i would not touch that, try flashing only main 4mb file and see what happens
        DELL INSPIRON 5520
        DELL MODEL No:5520-6928
        Country:LT
        Service Tag:254HGS1
        QCL00 LA-8241P
        Rev:1.0(A00)
        2012-02-10
        CPU
        INTEL SR0MZ
        AMD
        216-0833000
        E217A584
        SLJ8C
        ENE
        KB9012QF A3
        UH2
        cFeon QH16-104HIP
        UH6
        cFeon Q32B-104HIP
        • tiebone
          • Oct 2010
          • 17
          • Croatia
          I have seen that bios post and it is the same board but with the wrong graphics chip... I am not certain that it would work, at all...
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            if you wish to try i have extracted main bios 4mb from official bios update "7520A11.exe"
            • tiebone
              • Oct 2010
              • 17
              • Croatia
              Thanks, I will try it...and report...
              • tiebone
                • Oct 2010
                • 17
                • Croatia
                It is still not working and same behavior . It seems that the bios is not to blame. A hardware problem...7 beeps, but processor tested good. Just dont know if it is the PCH or the graphics chip...
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  that cpu beeps... it vga or chipset... i have had those symptoms before with dell m5030 n5030 and so on... after reflow it came to life, sometimes bios needed to be programmed after reflow... but with cpu beeps, changing the cpu never helped.... at least not for me
                  • fsushooter
                    • Mar 2015
                    • united states
                    Hey guys, I just replaced a failed Inspiron 7520 motherboard and learned more than I ever wanted about how Windows 8 key is embedded in OEM bios chip. Now my desktop has a watermark and is prompting me to activate windows 8 to no success.
                    Is there a full bios flash available that is pulled from a valid good bios that can restore the new motherboard to fix my issue?
                    Is switching bios chips from the old fried board to the new board a potential fix? I don't know what chip is the bios on the board so would have to figure that out too.
                    I am not into buying another copy of Windows 8 and Dell and Microsoft were less than helpful.
                    • puredeathly
                      • May 2015
                      • Austria
                      I would really need the hex file for the second (2mb) flash chip.
                      Two days after a bios update I got a rom checksum error and I tried a bios recovery (hold END while plugging in AC with a usb drive plugged in with the QCL01X64.fd on it) and something went wrong (the laptop shut itself off after about half an hour and then it was like dead. no lights. no reaction to any button press...).
                      After that I flashed the rom file posted above (the 4mb file) on the 4mb bios chip and it reacts exactly the same (still dead)...
                      Is the hardware defective or is the content of the 2mb chip wrong (can that even prevent the charging led from lighting up?)?
                      I hope that I can rescue my laptop without swapping the mainboard...
                      • heyman
                        • Feb 2016
                        • 4
                        Hi together.
                        I would also need the 2MB BIOS DUMP for the Dell 7520.
                        Same problem.
                        Is it possible to extract the ROM Files out of the QCL01A11.fd?
                        • kadi144
                          • Aug 2015
                          • 690
                          • algerie
                          Originally posted by heyman
                          Hi together.
                          Same problem.
                          fd=bin=rom
                          • heyman
                            • Feb 2016
                            • 4
                            Originally posted by kadi144
                            fd=bin=rom
                            I have to write the 2MB EEPROM in an external EEPROMER.
                            So I need only a part of the FD-File.
                            In the FD-Files there are both ROM-File included.
                            The 4MB and the 2MB.
                            Is there a way to extract both files out of the FD for using in an EEPROMER?
                            Or can I split the FD at a special position.
                            I think somewhere in the FD-File there should be a pointer to the 4MB and 2MB ROMs (or the pointer is in the INI-File which is included in the compressed EXE BIOS-Update-File).
                            • laptopservice
                              • Oct 2013
                              • 35
                              • india
                              thank you
                              • paserevictor
                                • Nov 2016
                                • 4
                                • Romania
                                ok thanks
                                • uchris
                                  • Apr 2017
                                  • Nigeria
                                  Thanks, it work
                                  • fsc2003
                                    • Mar 2015
                                    • 31
                                    • turkey
                                    thanks
                                    • cihancyber
                                      • Mar 2017
                                      • 22
                                      • tejhi
                                      thanks
                                      • UDPSendToFailed
                                        • Nov 2018
                                        • 3
                                        • Hungary
                                        Dell Inspiron 5520 (LA-8241P) dump needed
                                        Hi!
                                        My laptop got bricked with a BIOS update, it was fully dead, the END + charger method didn't work. I have tried to flash LA-8241P dumps to 2MB and 4MB ROM, but it's still dead, can't even turn it on. Is it possible I have downloaded not working dumps? Can some one send me working ones? Thanks a lot for help!
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • jamaica12345
                                          dell vostro 3710 bios dump needed
                                          by jamaica12345
                                          i need dump bios dell vostro 3710 please help
                                          Service Tag 2FL5NY3
                                          CI bios
                                          MX25L25635
                                          MX25L12805...
                                          09-29-2024, 12:34 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
