asus k43sv rev 3.0 bios
  • bios
    • Nov 2014
    • 64
    • Philippines
    Hi guys.. can anyone help me in my asus k43sv rev 3.0 I need bios dump for this model.
    Thank you..
  • techman1025
    • Jun 2014
    • 497
    Re: asus k43sv rev 3.0 bios
    Hi
    You need to upload your original file even if it curupted and i will give you a full working dump for your model .
    Techman1025
    • bios
      • Nov 2014
      • 64
      • Philippines
      Hello Sir,
      This is the Bios file, thank you in advance.
      • techman1025
        • Jun 2014
        • 497
        Here
        Techman1025
        • cyberhack
          • Feb 2013
          • 466
          • Uk
          Here
          • bios
            • Nov 2014
            • 64
            • Philippines
            Thank you for the help, I will try this.
            • GAMEL77
              • Feb 2015
              • indonesia
              Hai guy....asus a43sa kodeboard k43sa....no display....i have reflow vga card (ati).....but after it...i flash back with back up of this bios laptop ...it dead can't be turn on..can any one help me share your skema and bios?
              • patrickbui
                • Jul 2015
                • Vietnam
                Thanks bios, techman1025, cyberhack and thanks badcaps.net forum
                • raizenn27
                  • Jun 2011
                  • 97
                  • philippines
                  i have the same problem.and i already try it.,it really works .,thanks techman1025,cyberhack and sayo kabayan bios..
                  • alihomee
                    • Dec 2012
                    • 1599
                    • malaysia
                    i trued both bios but it restarts 3 times then gives display.its a asus k43sv rev:3 i5 with nvidia gt540
                    • neopozi
                      • Nov 2013
                      • 8
                      • Malaysia
                      I have tested both dumps from Techman and Cyberhack.. And they are working as expected.
                      Just sharing some feedback..
                      • rahmanianabbas
                        • Aug 2016
                        • iran
                        Originally posted by bios
                        Hello Sir,
                        thanks alot
                        • dolunay79
                          • Oct 2016
                          • 18
                          • turkey
                          thank you
                          • bachgaa
                            • Jun 2017
                            • Mongolia
                            Hi la-b092p rev:3.0 bios i need help me
                            • maggotcorpse06
                              • Dec 2012
                              • 12
                              • philippines
                              Hi newbie here how can i flash the bios ? same problem here i downloaded the bin then what? is there a program that i have to use or any key combinations? thanks
                              • techman1025
                                • Jun 2014
                                • 497
                                Hi you need a programmer like TL-866A LOOK on ebay real cheap ...cheap and itS good to do most jobs.
                                TECHMAN1025
                                • lv-tech
                                  • May 2019
                                  • philippines
                                  Do you have a bios for my k43sv rev.2.2 . Tnx for responding ^_^
                                  • razadom
                                    • Apr 2015
                                    • 106
                                    • Madagascar
                                    Hi all
                                    somebody can help me to unlock asus k43sa. I'll join to this message the bios dump
                                    • beal
                                      • Jul 2017
                                      • 125
                                      • IR
                                      Originally posted by cyberhack
                                      Here
                                      very thanks
                                      • dqtech
                                        Badcaps
                                        • Jul 2018
                                        • 641
                                        • N/A
                                        thanks
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
