asus k43sv rev 3.0 bios
  • dazokevin28
    kevinpogi
    • Jan 2021
    • Philippines
    Re: asus k43sv rev 3.0 bios
    thanks
    • mitu_sharma
      • Jul 2015
      • 182
      • india
      great job thanks
      • heri wahyono
        • Oct 2022
        • indonesia
        help me, asus K43SV GT540 hang
        • peste
          • 13924
          • ROMANIA
          post the original bios of the laptop..
          • heri wahyono
            • Oct 2022
            • indonesia
            my laptop bios version 3.0
            I have updated the bios but the problem is still there
            • peste
              • 13924
              • ROMANIA
              #26
              post the content of the bios chip...you need a SPI programmer..
              • thesleepwalker
                • Jun 2014
                • 12
                • Vietnam
                #27
                Anyone has the BIOS Dump for USB 3.0 chip please
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • pirati
                  by pirati
                  10-27-2025, 04:20 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
