DELL INSPIRON 15R 3521 BIOS Password
Re: DELL INSPIRON 15R 3521 BIOS Password
Last time I checked for a password in a Dell kbc, it was there in plaintext. Instead of rewriting, it might be easier to just read it.
flashrom + raspberry might do the trick as a programmer.Comment
But that's not the case in dell 3521 for sure.Comment
I do have a kbc programmer but how will that help you?? You need to own one for your purpose. there are many brands like svod,vertyanov etc.Comment
You can also try Raspberry Pi + Flashrom if you know how to set up and wire them.Comment
Password is in KBC, location 1E0C0, written in plaintext.Comment
go to https://bios-pw.org/
entre the code of system disabled plus the code of the ServiceTag like this
9387B94A96F3A4FF-3DT8QY1
hit entre and the password will generate
go to your locked laptop and entre the generated passwordComment
Hello Everyone i wan to share this method on how to unlock without reprogramme the IO chip
https://www.badcaps.net/forum/showth...51#post1229251
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
THANK YOU SO MUCH BRO
I NEED DELL INSPIRON 15-3521 BIOS PASSWORD TO UNLOCK
System Disable
0F4D3B8CF660C71D
SERVICE TAG
46DKCW1Comment
System Disable
0F4D3B8CF660C71D
SERVICE TAG
46DKCW1Comment
Channel: BIOS Requests ONLY!
by tariom18mDell Vostro 5415 bios Password MOD EDIT: INSPIRON 5415 NOT VOSTRO
Hi could anybody help me with removing bios password please or supply clean me bios for Dell Vostro 5414 MOD EDIT: INSPIRON 5415 NOT VOSTRO
Système disable
5B8336EF14B92F31
SERVICE TAG
5ZYRHG3
Thanks in advance-
by zlr8rlooking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
cheers
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
MOBO: RO 15 17 WHL 2GB MB / 18706-2
Attached;
1. My saved bios using a programmer
2. Dells Bios updater .exe (v1.16)
3. Dells Bios recovery file
4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
5. Image of ME...-
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by GadgetsFixHi everyone,
I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
- Model: Dell Inspiron 16 5630
- MainBoard Part Number: 4550SC01C004
- Laptop Serial No: GKH3JX3
- DP/N: 0303KM
- QUAKE N RPL UMA CS MB
- 213251-2
- TMN0H$KB
Thanks-
01-17-2025, 07:38 AM - Loading...
