Hp 15-d025ee bios need, urgent please
  • nazrul145
    • Jan 2014
    • 335
    • BD
    Hello there, Hp 15-d025ee has no display. so i need program bios. if anyone have this i request help me. i attachaced orginal dump here.
    PN: 010194Q00-491-G
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: Hp 15-d025ee bios need, urgent please
    Give mobo code
    • nazrul145
      • Jan 2014
      • 335
      • BD
      thanks for reply.
      motherboard code is
      010194Q00-491-G
      • khaahk
        • Dec 2013
        • 766
        • Estonia
        From hp site:
        • nazrul145
          • Jan 2014
          • 335
          • BD
          Thanks Khaahk, I will check and lets u know
          • akril1
            • Nov 2017
            • dil
            • ciborgec
              • Jan 2017
              • Ecuador
              if someone needs to know, nazrul145´s backup works. I have the same PN: 010194Q00-491-G .anyway my laptop is 14" display
              • tokesszabi
                • Mar 2015
                • 12
                Sorry for hacking the thread but my problem is somehow related.There is this HP 15-d054sq, with board number 010194q00-491-g.The laptop does not power on,wifi key lights and capslock blinks slowly .There for must be a bios issue.So I backed up the old bios from main ic and flashed already many variants found even here.But this bios has tho parts main+kbc. I cannot found backup for kbc.And the official bios files extracted are joined together.Somebody can split encripted EFI bios files?Or backup file from KBC ic?Thanks in advance.
                • moin
                  • Nov 2019
                  • India
                  i need 01019b600-491-g bios
                    • 20873
                    Bios + EC .
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • MDSI
                      HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                      by MDSI
                      I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                      Details:
                      Model : HP OMEN 17-an012nf
                      Motherboard Part Number : DAG3BAMBAF0 REV : F
                      Serial Number (S/N) : 5CD7280D51
                      BIOS chip : Winbond W25Q64VSIQ
                      Programmer : EZP2023+
                      Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                      I already...
                      07-28-2025, 07:11 AM
                    • grimacelord
                      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                      by grimacelord
                      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                      Motherboard model number: DA0PAMB46A1 REV: A
                      Secondary motherboard model number: 0PAB
                      SKU: 685K4UA
                      Serial number is: 5CD3223BJP
                      Recently reflashed this laptop with latest BIOS and once...
                      05-07-2024, 08:06 AM
                    • DynaxSC
                      Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                      by DynaxSC
                      I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                      It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                      I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                      11-06-2022, 05:22 PM
