i need working bios for Asus x71SL
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • grimacelord
    by grimacelord
    07-10-2025, 02:52 PM
  • ronaldopdias
    ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
    by ronaldopdias
    I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
    • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
    • BIOS file downloaded directly from the official ASUS support page.
    • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
    Issue:
    The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
    Because FlashBack didn’t work, I:
    • Removed the BIOS SPI IC from
    02-04-2026, 03:16 AM
  • kara
    Asus GX501v keyboard not working - keyboard firmware - solved!
    by kara
    Hello, i had a problem with this laptop keyboard. not working even after replacing with new original palmrest.
    Solution after hours of researching is using a small software found on asus forum !
    https://rog-forum.asus.com/t5/rog-ga.../701169/page/6
    Thank you Bogdan Ciulei
    Finally some good news :
    I have managed to fix the problem.
    First,
    I am not responsible for any damage you might do to your hardware !
    YOU DO THIS AT YOUR OWN RISK ! I ONLY PROVIDE POINTERS , DO
    12-09-2025, 02:27 AM
  • TyMercer
    Can I flash a working BIOS from one computer to another of the same make, model, etc?
    by TyMercer
    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
    11-13-2025, 09:39 PM
