Lenovo V130-15IKB bios dump
  • borbooroski
    • Mar 2014
    • 177
    • Ghana
    please Can Someone please help me with this Lenovo V130-15IKB Bios Bin
  • peste
    • 12872
    • ROMANIA
    Re: Lenovo V130-15IKB
    post the bios backup
    • borbooroski
      • Mar 2014
      • 177
      • Ghana
      Please i dont understand the Bios Background......please help me out.
      • peste
        • 12872
        • ROMANIA
        post the original bios of the laptop..extract the content from the bios chip, make a copy, and post it here ..
        • mangus
          • Nov 2017
          • 11
          • Lietuva
          I have Lenovo V130-15IKB, model name 81HN and suddenly it dies. Screen is showing nothing, but that is not screen problem. Only beep if I plug charger. Maybe it has bios problem, so I will try to flash bios dump before give to service for further inspections or just part it out. Thanks.
          • mangus
            • Nov 2017
            • 11
            • Lietuva
            Re: Lenovo V130-15IKB bios dump
            Still need bios dump for this lenovo laptop. Maye someone has it?
            • peste
              • 12872
              • ROMANIA
              post the backup copy of the original laptop bios
              • mangus
                • Nov 2017
                • 11
                • Lietuva
                Here it is
                • peste
                  • 12872
                  • ROMANIA
                  Here it is
                  try..be careful when writing..the bios posted by you is longer ..
                  • mangus
                    • Nov 2017
                    • 11
                    • Lietuva
                    Thank you. This one worked. Now this notebook finally posts. In bios menu, shows invalid mtm and lenovo SN and also UUID number shows only zeros. That probably doesn't affect system stability but maybe there is utility to fix those?
                      • 21022
                      Try this bios.
                      • mangus
                        • Nov 2017
                        • 11
                        • Lietuva
                        Originally posted by SMDFlea
                        Try this bios.
                        Thank you very much. Now everything as used to be
                        • huss584
                          Hussein
                          • Apr 2020
                          • 228
                          • Palestine
                          Re: Lenovo bios V330-15IKB
                          Hello Every Body
                          need Bios
                          Attached My Backup
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria šŸ‡§šŸ‡¬
                            Originally posted by huss584
                            Hello Every Body
                            need Bios
                            Attached My Backup
                            Try (SMDFlea file from #11 + your DMI / Winkey is XXXXX-...):
                            Become a Badcaps supporter
                            Thanks to all supporters.​
                            • huss584
                              Hussein
                              • Apr 2020
                              • 228
                              • Palestine
                              After this ,no power at ALL
                                • 21022
                                Is the serial number on the case R90YYK1H
                                • huss584
                                  Hussein
                                  • Apr 2020
                                  • 228
                                  • Palestine
                                  Yes the SN:R90YYK1H
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria šŸ‡§šŸ‡¬
                                    Yes the SN:R90YYK1H
                                    What programmer do you use, also do you read /write the chip in circuit with the clip? Did you verified the chip content after programming?
                                    • huss584
                                      Hussein
                                      • Apr 2020
                                      • 228
                                      • Palestine
                                      SuperPro 610p
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria šŸ‡§šŸ‡¬
                                        SuperPro 610p
                                        How about answering all the questions?
                                        In short do it again, use verification, and so on. This dump should work, as you can see it's confirmed working.
                                        • AHmad_Salal
                                          Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                          by AHmad_Salal
                                          Hello all,
                                          I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                          11-28-2023, 05:28 AM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • hyperwood
                                          [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                          by hyperwood
                                          I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                          The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                          I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                          āœ… What I need:
                                          • A working 2MB BIOS dump
                                          • Matching NM-E471 Rev. 2.0, e.g. JY575
                                          06-25-2025, 02:28 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Joluvillas
                                          Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                          by Joluvillas
                                          Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                          06-18-2024, 10:35 PM
