840 G1 BIOS MOD HELP
  • Zilicon
    • Nov 2020
    • 152
    • Nigeria
    Greetings everyone.
    Please i need help in building a flashable BIOS firmware from exe executable.
    please, i need a tutorial on how i can achieve that.
    I'm currently working on Elitebook 840 G1. the user forced to shutdown when the PC was updating. the pc does not recognized HDD or NGFF since then. i've fetch various BIOS dump but none helped.
    i want to try to build the firmware from the update.
    I have fetched the updated file and extracted it with 7-zip, the bin file size is 8mb, meanwhile the BIOS image file is 16mb.
    the extracted file did not contain the ME region. this is where i need help so that i can have the total 16mb flashable file.
    i will appreciate learning how to do it. any tutorial will be appreciated.
    thank you all
    • 22109
    Look for another bios chip, it might be on the other side of the board. When you find it post your backup and Type the laptop serial number, full name and model, motherboard model, etc.
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    • Zilicon
      • Nov 2020
      • 152
      • Nigeria
      Thank you so much SMDFlea.
      There is another BIOS chip, 2MB, beside the main BIOS. Attached are the backups of the file and the backup of the main BIOS.
      However, I can't vouch for the originality of the backup file, because the PC has been taken to at least one repairer before I laid my hands on it.
      SN: 5CG51239VX
      full name: HP EliteBook 840 G1
      model: Elitebook 840 G1
      MoBo: 6050A2559101-MB-A03
      PCID: A3009DD10203
      Product: G8J02US#ABA
      • hoaca388
        Badcaps
        • Jan 2022
        • 12419
        SN: 5CG51239VX
        PCID: A3009DD10203
        I thought EC was an 8MB or 16MB file, not 2MB. Maybe you misread the chip.
        ​https://www.badcaps.net/donate
        • Zilicon
          • Nov 2020
          • 152
          • Nigeria
          I made several backups, all were the same size.
          the size also coincide with the bios dump+EC that I found on the net- 16mb and 2mb respectively
          • Zilicon
            • Nov 2020
            • 152
            • Nigeria
            Greetings everyone,
            please, i still need help for the above. I've not been able to figure it out yet.
            • volinakis
              • Jan 2021
              • 2875
              • N/A
              Greetings everyone,
              try
              • Zilicon
                • Nov 2020
                • 152
                • Nigeria
                Originally posted by volinakis
                try
                just seeing this, thank you so much. i will try and revert
                • to5it0
                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                  by to5it0
                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                  I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                  This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                  I have opened the laptop and identified the main BIOS chip...
                  10-24-2025, 01:35 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • maanee11
                  Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                  by maanee11
                  Hello Everyone,
                  I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                  It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                  In the website, you can only see specs etc.
                  I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                  11-08-2025, 04:08 AM
                • m1ch43lzm
                  Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                  by m1ch43lzm
                  Hi everyone
                  I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                  Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                  Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                  There's also an extra OTP Secu.R...
                  09-06-2025, 05:47 PM
                • Sebastian Codrean
                  BIOS file for ASUS F542UN laptop
                  by Sebastian Codrean
                  Hello to all of you! I need help with a BIOS file.
                  The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                  So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                  02-20-2025, 10:25 AM
