Dell XPS 15 9520 BIOS Password
  • Kuro_Ni
    • May 2025
    • 5
    Hi!
    This is my first post over here, and I hope I'm properly following the instructions.
    I recently got a XPS 15 9520 that (sadly) has an admin password, which normally wouldn't be a problem, but this model has support for RAID using the 2 NVMe slots.
    Using bios-pw is sadly not an option since it has an 8FC8 suffix. I tried dumping the BIOS and patching it since I just got a CH341A and a clamp. Sadly, I was not able to properly attach it since I believe the clamp I got is of really bad quality and I have no confidence in my soldering skills. I would greatly appreciate some help unlocking it.
    Model number: Dell XPS 15 9520
    Service Tag: 2L096W3​-8FC8
    motherboard model and revision: hd051/hda51 la-l402p Rev: 1.0 (A00)
    All help will be appreciated.
  • lapfix
    • Mar 2020
    • 2765
    • my workshop
    Originally posted by Kuro_Ni
    Hi!
    the only way to help you is to upload your dump...so be carefel
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • mikeybass
      by mikeybass
      04-23-2025, 04:30 PM
    • capoplays
      Help with BIOS update on Dell G15 5515 after chip replacement
      by capoplays
      Hey everyone,
      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
      When I check the BIOS using the F12 menu Flash...
      10-24-2025, 06:53 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • Sathsul
      Dell Latitude 5431 issues with dumping bios
      by Sathsul
      So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
      The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
      However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
      10-28-2025, 07:49 AM
