NR2202RX R1.2 bios
  • Tondo27
    • Aug 2024
    • 12
    • slovakia
    NR2202RX R1.2 bios
    Good day, I would like to flash the BIOS of a notebook that turns on but remains on a black screen. It is an AMD version. I have tried to find it on the Asus websites but to no avail. If you could help me, I would be very grateful. I will attach the original BIOS.MODEL: ASUS GX650RX-xs97
    S/N: N3NRKD011944126
    Motherboard: NR2202RX R1.2
    Thanks.
  • Tondo27
    • Aug 2024
    • 12
    • slovakia
    Does anyone have a working bios for this laptop asus zephyrus duo 16 gx650rx? NR2202RX REV. 1.2 thanks
      • 20990
      Your posts have been moved to a new thread topic as your motherboard revision is 1.2 .Post pictures of the barcode and/or QR codes on the motherboard
      • hardware1
        • Sep 2021
        • 2936
        • N/A
        Thanks.
        Here is your new file, it's a virgin BIOS from ASUS with your DMI and Windows Key.
        I got this file according to your Serial Number (N3NRKD011944126), I also found the same Serial in your file, so I assumed it's your original BIOS.
        Anyway, it's always better to look for QR on your motherboard and post an image for it (as SMDFlea told you.)
        all donations are welcome,
        • Tondo27
          • Aug 2024
          • 12
          • slovakia
          I am attaching another qr code from the board. It seems that the bios started working, but I still don't have a picture and the fans don't start. But after flashing the bios, the vcore voltages also start working. It seems that all the power supplies are working except for the PEX vdd. Is it possible that the VBIOS is also damaged?. The EN voltage and the VIN voltage are working on the chip, the powergood does not work​. thanks.
          • hardware1
            • Sep 2021
            • 2936
            • N/A
            If you press on the Caps-lock key, its LED is responding or you can hear any sound while entering BIOS Setup for example? Have you tried to check your LCD and the LCD ribbon cable? Tried to connect the laptop to an external monitor through HDMI?
            It don't know about the vBIOS, but you can send the file, write your GPU details and we will try to find another one for you.
            • Tondo27
              • Aug 2024
              • 12
              • slovakia
              Hello. I looked and capslock doesn't respond, only the cpu and gpu are heating up. All voltages are working except pex vdd. I also tried hdmi without any results.
              • hardware1
                • Sep 2021
                • 2936
                • N/A
                It could be a Hardware issue. Maybe someone else can give you a file to try it. I tried to find another similar BIOS but I can't find it anywhere.
                • Tondo27
                  • Aug 2024
                  • 12
                  • slovakia
                  It's okay. I'll try to find out if someone has a similar notebook so they can provide me with the BIOS for the trial. Thank you.
                  • pooya_pm
                    • Jan 2021
                    • 254
                    • iraq
                    PLS SHEAR WORKING BIOS
                    • shiyab
                      • Sep 2023
                      • 1483
                      • india
                      post backup bios and snid
                      • Tondo27
                        • Aug 2024
                        • 12
                        • slovakia
                        Hello. I would like to ask if you could remove the nvidia gpu from the bios so that the laptop starts via igpu and does not detect the nvidia gpu and the post runs. I suspect that the laptop is working but detects a damaged gpu and therefore the post does not run completely. thanks
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • grimacelord
                          by grimacelord
                          07-10-2025, 02:52 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          06-18-2025, 05:52 PM
                        • lrouw84
                          by lrouw84
                          Hi there,
                          01-28-2023, 01:31 PM
