  • jbonavita
    • Jan 2017
    • 10
    • argentina
    Some issues
    Things I tried
    1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...-guide?t=88533
    to no good results (same behaviour from the original BIOS)
    Things I noticed
    Backup bios size : 8 MB
    TP500LN donwloaded BIOS from this forum : 8MB
    Bios for model TP500LA downloaded from ASUS support : 6 MB
    So, Im in need of:
    - A normal backup of a working bios for TP500LA (8 MB) for direct flashing
    - A merge from the ASUS webpage 6 MB BIOS and the part of the TP500LN BIOS that made it work
    - Repair or something my original BIOS
    As of now, Im thinking to cut a part (2 MB) from the 500LN bios and merging to the 6 MB 500LA to make a 8 MB one, but I dont know how
    Thanks in advance
  • LEO037_2029_
    BIOS_LEGEND
    • Nov 2023
    • 83
    • Argentina
    try and feedback bro ( prueba y comentame amigo).
    • shiyab
      • Sep 2023
      • 1414
      • india
      Thanks in advance
      post snid
      • jbonavita
        • Jan 2017
        • 10
        • argentina
        Thanks, I will flash it right now, later post a feedback
        Originally posted by shiyab
        post snid
        Are you refering to serial number ID? I´ts TP500LA-DH71T
        • shiyab
          • Sep 2023
          • 1414
          • india
          yes
            • 20818
            He was referring to the serial number, but it`s not TP500LA-DH71T , the serial is about 15 digits long
            https://eu-rma.asus.com/img/info/nb_serial2.jpg
            https://eu-rma.asus.com/uk/info/sn
            • jbonavita
              • Jan 2017
              • 10
              • argentina
              Oh, I get it.
              SNID EAN0WU51172144C
              • jbonavita
                • Jan 2017
                • 10
                • argentina
                Flashed it and the notebook boots fine, but the easy flash option in BIOS is showing " please plug in battery and its remaining capacity should be more than 20%. System doesnt permit flashing BIOS. Please press any key after pluging the battery"
                Pressing a key does nothing, the battery is internally connected already
                • jbonavita
                  • Jan 2017
                  • 10
                  • argentina
                  Tested merge.bin. and worked flawlessly, the notebook boots as normally do, no delays etc. But now is has no serial number installed. I have battery problems and MyAsus app doesn´t recognize this machine (to try some calibration, etc). It is possible to re-add the SNID posted above? thanks
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11715
                    Here
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • lrouw84
                      by lrouw84
                      Hi there,
                      01-28-2023, 01:31 PM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
                    • chudofermer
                      Asus Ally rc71l bios
                      by chudofermer
                      Hello!
                      Received Asus Ally rc71l with the wrong bios.
                      Have the original package and all serial numbers.
                      Can anyone help me understand what is wrong?
                      Condition:
                      Received with an original box with all serial numbers
                      Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
                      Got the flash dump, nothing found on DMI section
                      No Windows key, just key ID on the box
                      What is done:
                      1. Flash the latest bios version with serial numbers...
                      03-05-2025, 05:42 AM
                    • maciek1221
                      Looking for a bios for Asus G512-LV with RTX2060 and bios for VGA chip
                      by maciek1221
                      Hello, I am looking for a bios insert for the Asus Rog Strix G512LV-HN235T laptop. We are looking for input for both the BIOS and the small chip for the graphics card. The laptop came to me after another service with the wrong BIOS (no serial number, the problem with the meregion turns on for more than a minute). After uploading a few batches, I have an exclamation mark next to the Nvidia RTX2060 graphics card, I suspect one of the 2 BIOS batches is incorrect.
                      Config:
                      Model: Asus G512LV-HN235T
                      Platforma: G532LWS rev. 1.3
                      CPU: intel i7-10870H
                      GPU: nVidia Geforce RTX2060/...
                      03-07-2024, 07:54 AM
