HP Laptop 17-cp0290nf
This topic has been answered.
  • Genova
    • Jan 2020
    • 118
    • FRANCE
    I'm a little annoyed with this pc that won't recover.
    HP recovery starts well but it seems that bios recovery goes too quickly, Pc reboot, recovery process messages appear but after the last pc reboots the pc turns on but no screen display, even after 20 minutes.
    65Z38EA
    SN:5CG2110HF6
  • Answer selected by Genova at 04-09-2025, 08:54 AM.
    SMDFlea
    • 22286
    Originally posted by Genova
    Thank you SMDFlea but ;
    Offsets: 413000 ok - 41403F did you mean 414030 ?
    435000 ok - 43503F did you mean 435030 ?
    The DMI offsets are 413000 to 41403F .The windows key offsets are 435000 to 43503F .I always add extra to the end offset for the widows key as there is one character on the last row with the rest FF`s. Its easier to remember when the length is 40
    Click image for larger version  Name:	offsets.jpg Views:	0 Size:	114.1 KB ID:	3611188
      • 22286
      65Z38EA
      SN:5CG2110HF6
      Use the Guides to find and extract a virgin bios
      [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
      [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
      Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (select block in HxD) in both bios,copy from the old,paste to the new.
      Offsets: 413000 - 41403F and 435000 - 43503F
      HxD Hex editor https://mh-nexus.de/en/hxd/​
      • Genova
        • Jan 2020
        • 118
        • FRANCE
          • 22286
          • Genova
            • Jan 2020
            • 118
            • FRANCE
            Thanks a lot SMDFlea for yours explanations, bios is recovered. Manufacture Programming Mode in Unlock mode at start, easily reset with BCU program.
              SMDFlea commented
              Editing a comment
              You`re welcome ;-)
          • volinakis
            Chromebook recovery failed - how to fix it
            by volinakis
            So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
            Finally I found a site where they suggested to try with an older image and ... it worked!
            What I did:
            - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
            09-18-2023, 03:26 PM
          • myth77
            macbook pro a2141 can not make recovery
            by myth77
            So, i dont know almost anything on macs..but this is my nephews so i had to try. Its 16 inch macbook pro from 2019...It all started when he left something on the keyboard when closing the mac and there it was the crack on screen. At first it was like working but later no. After that he told me that it wouldnt power on?...hear fans but nothing..tried like 100 of stuffs but nothing helped.
            So, he bring it to me...first i open it and figured he did also. there was lots of dust i cleaned everything...and started it...the broken screen showed only backlight but nothing on the screen. I...
            06-19-2022, 11:21 AM
          • ugamazing
            820-00850 & 820-01949, No WiFi *In Recovery*
            by ugamazing
            I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
            1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
            2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
            01-25-2023, 05:39 PM
          • alfredposadas09
            cant enter recovery mode lenovo c13 yoga chromebook
            by alfredposadas09
            cant enter recovery mode lenovo c13 yoga chromebook try esc+refresh+power at first scenario i was able to enter recovery mode but it was failing to reinstall os .. i try to change ssd and when i try this i cant enter recovery mode now...
            11-09-2024, 10:09 AM
          • conghuyms
            Macbook air m1 can't access the recovery options by pressing and holding the power button
            by conghuyms
            I have an M1 MacBook Air (A2337) 2020 that came in for water damage and will not turn on. Upon opening it, I saw that the audio board was severely corroded. I disconnected it, and the device started working.
            After that, I dealt with the issues on the audio board by removing the capacitors that were shorted to ground, and the device started working. However, I encountered another problem: I can't access the recovery options by pressing and holding the power button. I'm not sure if it's a hardware issue or if the recovery partition has been lost. Currently, the system's time isn't updating,...
            10-14-2024, 06:43 AM
