HP Laptop 17-cp0290nf
This topic has been answered.
    I'm a little annoyed with this pc that won't recover.
    HP recovery starts well but it seems that bios recovery goes too quickly, Pc reboot, recovery process messages appear but after the last pc reboots the pc turns on but no screen display, even after 20 minutes.
    65Z38EA
    SN:5CG2110HF6
  • Answer selected by Genova at 04-09-2025, 08:54 AM.
    Originally posted by Genova View Post
    Thank you SMDFlea but ;
    Offsets: 413000 ok - 41403F did you mean 414030 ?
    435000 ok - 43503F did you mean 435030 ?
    The DMI offsets are 413000 to 41403F .The windows key offsets are 435000 to 43503F .I always add extra to the end offset for the widows key as there is one character on the last row with the rest FF`s. Its easier to remember when the length is 40
    Click image for larger version  Name:	offsets.jpg Views:	0 Size:	114.1 KB ID:	3611188
      65Z38EA
      SN:5CG2110HF6
      Use the Guides to find and extract a virgin bios
      [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
      [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
      Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (select block in HxD) in both bios,copy from the old,paste to the new.
      Offsets: 413000 - 41403F and 435000 - 43503F
      HxD Hex editor https://mh-nexus.de/en/hxd/
            Thanks a lot SMDFlea for yours explanations, bios is recovered. Manufacture Programming Mode in Unlock mode at start, easily reset with BCU program.
              SMDFlea commented
              Editing a comment
              You`re welcome ;-)
