T470 and 0285 error
  • kicker12
    • Jul 2022
    • 19
    • Italy
    T470 and 0285 error
    Hi everyone!
    I have a T470 which makes beeps at the startup and they lead to 0285 error (TCG-compliant functionality-related error (might be the TPM initialization failure)).
    I have read a bit around and looks I may try to upload a new/modified BIOS: I am attaching the dump of the original one (defective).
    Anyone can point me to the right direction on how to move next???
    Type: 20JN-S5UV00
    Serial: PF-1J98FY
  • volinakis
    • Jan 2021
    • 2875
    • N/A
    Originally posted by kicker12
    Hi everyone!
    Type: 20JN-S5UV00
    Serial: PF-1J98FY
    Bios_Region of your bios is corrupted (empty). try this file and write DMI with LMU (Lenovo Maintenance Utility).
    • SmartSmurf
      T470 not starting - error code 0285
      by SmartSmurf
      My good old T470 out of sudden hung while starting up, unable to power off while pressing the power switch for a minute or so. After 10 minutes I removed the battery.
      Now the BIOS plays the 0285 sound (decoded with diagnosis app).
      The BIOS was not protected by user nor supervisor password.
      I have no flash dump, but I am experienced to dump it. Is it worthwhile? I read that this error can be solved my deleting the ME part of the BIOS.
      Any advise?
      07-09-2023, 04:06 AM
    • fredyjbi
      please help friends thinkpad T470 error post "bottom cover tamper detection error"
      by fredyjbi
      please help friends thinkpad T470 board CT470 series NM-A931 error post "bottom cover tamper detection error"
      I've already
      flashed the bios clean me and updated from the Lenovo site, then removed the switch and immediately jumped the S3 from pins 1 to 4, 2 to 3 but the problem remained the same, thank you
      06-15-2024, 09:56 AM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • sushilachuthan
      APC UPS error P13
      by sushilachuthan
      one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
      the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
      The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
      We replaced the SCR with new device,, but the device is not power on as expected.
      Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
      09-26-2025, 09:00 AM
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
