HP VICTUS 16-r00**** LA-M787P
  • surn
    • Dec 2021
    • 6
    • España
    Hi! First of all, I want to say that I have read the rules and followed the procedures, but I haven't been able to fix the issue.
    Let me explain my problem: I have an HP VICTUS 16-r0028ns, motherboard model LA-M787P, serial number CND3221BF1. The laptop had a short circuit on the motherboard, and after repairing it, I connected the power cable. The fans would spin, but the screen wouldn't turn on, and nothing happened. Then, the laptop would shut down again.
    The device came from another repair service, I decided to replace the BIOS. I went to HP's official website and tried both BIOS options available. From that moment on, the laptop stopped working completely—it only turns on the power LED, and the Caps Lock key blinks once before all keyboard LEDs turn off.
    After that, I reflashed the original BIOS, but the problem remained. Now, not even the fans spin—same issue as with the official BIOS.
    So, I decided to clean the ME region using the FIT tool, but the problem persists. The power consumption is around 0.06 - 0.08 A, and all voltage lines seem to be correct.
    I don't know what else to do. I'm attaching the original BIOS because I think I might be doing something wrong.
    Thank you very much.
  • volinakis
    • Jan 2021
    • 2734
    • N/A
    try
    • surn
      • Dec 2021
      • 6
      • España
      Originally posted by volinakis
      try
      thanks you, but the same problem, i think thats its possible an EC problem.
      Thanks for your time i apreciate it.​
      • Simon16
        • Sep 2017
        • 100
        • España
        Please, help me
        HP VICTUS 16-R0019NS
        S/N: CND3340L59
        MB: JPR68 JPR6D LA-M787P REV 2.0
        BIOS CHIP: W25R128JV
        • peste
          peste commented
          Editing a comment
          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
          SMDFlea commented
          Editing a comment
          Post moved to 16-r00**** LA-M787P thread topic.
      • peste
        • Dec 2016
        • 12859
        • ROMANIA
        Originally posted by Simon16
        Please, help me
        S/N: CND3340L59
        try post#2...
        DMI 680000 - 680FFF
        • Simon16
          • Sep 2017
          • 100
          • España
          Hello
          Thank you very much and sorry for the mistake of posting where it didn't belong.
          I wrote bios post #2 with my DMI and now it turns on, but after a minute it turns off by itself.
          I suspect the GPU or CPU will also fail​
          • peste
            • Dec 2016
            • 12859
            • ROMANIA
            Hello
            maybe it's overheating...
            • Simon16
              • Sep 2017
              • 100
              • España
              Now i think it may be the EC.
              When connecting a mouse and a keyboard via USB I have been able to verify that it does not turn off but loses the image and the power LED turns off (on the power key, on the keyboard) but remains on. The power key no longer works until I remove the power and the battery.
              I think it may be the EC since the keyboard is controlled by the EC.
              I attach the EC file.
              EC CHIP: UV4 W25Q16JW
              Can you provide me with a valid ec file for HP VICTUS 16-R0019NS
              S/N: CND3340L59?
              Thanks in avance
                • 20984
                EC CHIP: UV4 W25Q16JW​
                That isn`t the EC, it`s the Nvidia vBios
                • Simon16
                  • Sep 2017
                  • 100
                  • España
                  Ok, thanks... glubsssss
                  • Simon16
                    • Sep 2017
                    • 100
                    • España
                    I have written the ec by doing the following:
                    First I have written an older version of the bios using the TL866 II PLUS programmer
                    Then I have created a USB with the latest version of the bios and the ec using the file downloaded from the HP website (I attach the file for anyone who may need it)
                    And finally I have installed the latest bios and the latest EC firmware with the USB by pressing Windows + B when turning on.
                    After this I thought it was already solved because I have left it on the bios screen for a long while and it did not lose image when before it failed in less than 5 minutes.
                    But later I tried to install Windows 11 and everything was fine but there came a time when it started to lose the image and recover it.
                    In short, it has failed again. It has taken longer and it does not lose the image radically as before nor does the power key LED turn off permanently but flashes but fails.
                    I wonder if anyone knows if re-soldering the EC chip pins can definitively solve the problem.
                    Or if it will be necessary to change the chip.​
                    • madjid911
                      • Dec 2016
                      • 390
                      • France
                      Hello, can you unlock the bios password for me please, I tried with unlocker but the password is still there.
                      SN : CND315143P
                      LAPTOP 16-R0024NF
                      Mother-board LA-M787P rev 2.0
                      • shiyab
                        • Sep 2023
                        • 1483
                        • india
                        SN : CND315143P
                        LAPTOP 16-R0024NF
                        hi try
                        • madjid911
                          • Dec 2016
                          • 390
                          • France
                          Originally posted by shiyab
                          hi try
                          16MB_UNSS still has the password, and 08BBD shows nothing
                          These are the original bios that we find on the site. I had already tried. Maybe the password is not in the bios chip?
                          • madjid911
                            • Dec 2016
                            • 390
                            • France
                            I just tested post 2 and it works I no longer have a password, I think the back cover was not the right one so the serial number was not the right one.
                            I have an error message stuck in manufacturing, do you have a simple solution for this?
                            • minhdigital
                              • Nov 2022
                              • 757
                              • Vietnam
                              Send to you, try !!
                              • Securedwired
                                • Jun 2024
                                Hi, i have the same problem. Do u solved this ?
                                • Simon16
                                  • Sep 2017
                                  • 100
                                  • España
                                  English translation !
                                  Yes, it was the CPU. I resoldered it and everything worked fine.
                                  • Vesko356
                                    by Vesko356
                                    08-11-2023, 03:27 AM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • Wahaz
                                    by Wahaz
                                    10-30-2023, 08:42 PM
                                  • Bloodhoundje
                                    HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                    by Bloodhoundje
                                    I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                    I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                    After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                    I have desoldered the bios chip (GigaDevice...
                                    03-16-2024, 03:12 PM
