HP 360x convertible 15-er1250nd broken BIOS
  • dr.thodt
    • Apr 2016
    • 87
    • Netherlands
    This laptop crashed during BIOS update and won't start anymore. Please help:
    Model: HP 360x convertible
    Model nr: 15-er1250nd
    S/N: 8CG343000G
    Many thanks in advance.
    • 22286
    S/N: 8CG343000G
    Use the Guides to find and extract a virgin bios
    [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
    [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
    Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (Edit -> Select block in HxD) in both bios,copy from the old,paste to the new.
    Offsets: 700000 - 70103F
    HxD Hex editor https://mh-nexus.de/en/hxd/
    • princepal
      • Feb 2019
      • 37
      • india
      S/N: 8CG343000G
      try and update
      • dr.thodt
        • Apr 2016
        • 87
        • Netherlands
        Got it to work. Thanks.
        • princepal
          • Feb 2019
          • 37
          • india
          can you share the part number of this motherboard.
          • dr.thodt
            • Apr 2016
            • 87
            • Netherlands
            I'm sorry, the customer already took it home.
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • akwky
              by akwky
              Hi!
              04-14-2025, 01:56 PM
            • al3m0di
              Update bios EFCN58WW to EFCN59WW
              by al3m0di
              Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
              I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
              The BIOS version is EFCN58WW.
              When I turn on the device, it displays the message:
              "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
              The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
              I've tried
              07-29-2024, 10:32 AM
            • capoplays
              Help with BIOS update on Dell G15 5515 after chip replacement
              by capoplays
              Hey everyone,
              I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
              The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
              When I check the BIOS using the F12 menu Flash...
              10-24-2025, 06:53 AM
            • 0xx
              2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
              by 0xx
              Hi folks,
              My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
              What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
              I assumed that Windows Update was interrupted due to closing...
              09-14-2025, 03:46 PM
