Asus X413F - motherboard X421FAY R2 bios
  • roxor56k
    • Oct 2023
    • 5
    • France
    I have a problem with a Asus laptop. Serial number is L6N0CX07210424E
    Motherboard is X421FAY R2.0
    Black screen, two blinks of battery led.
    Can anyone look at the bios dump ? I think it is bios problem. Thanks ! πŸ˜‰
    • 22077
    Post a picture of the QR code by the SSD socket
    • roxor56k
      • Oct 2023
      • 5
      • France
      Thanks, here it is !
      • roxor56k
        • Oct 2023
        • 5
        • France
        Hi, I tried to do it myself with the tutorial but I didn't succeed ...
        https://www.badcaps.net/forum/troubl...t-by-razor_amd
        Thanks you
        • hoaca388
          Badcaps
          • Jan 2022
          • 12392
          Thanks you
          Try
          ​https://www.badcaps.net/donate
          • roxor56k
            • Oct 2023
            • 5
            • France
            Thank you !
            Flashed OK, but still no luck ... Two blinks of the​ charging lights... Maybe it is dead ! πŸ˜‰
            • oragano
              ASUS ex-b250-V7 motherboard bios corrupted - by me
              by oragano
              hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
              So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
              i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
              10-17-2024, 02:53 AM
            • lucaszmn
              by lucaszmn
              Problem:
              Initial Findings:
              • I concluded that the
              08-12-2025, 03:01 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • AquaMan Ua
              Problem with PANASONIC CF53 laptop after changing BIOS settings
              by AquaMan Ua
              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
              05-17-2025, 09:40 AM
