Asus g750jx Bios turns off after 30 minutes
  • Newmultifail
    • Dec 2024
    • 5
    • Serbia
    I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again?
    I should mention that the bios update did not help.
    backup i sn
    I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again? I
  • peste
    • Dec 2016
    • 12859
    • ROMANIA
    backup i sn
    post the S/N, post the original content of the bios chip, the motherboard model, etc.
    ​post the bios here on the site, not on other sites...
    • Newmultifail
      • Dec 2024
      • 5
      • Serbia
      SN/ D6N0CY359870244
      Asus G750JX-T4167H
      MB/ G750JW REV. 2.1
      Noticed after bios update the serial number disappeared
      • mrwab
        Banned
        • Jan 2014
        • 83
        • morocco
        SN/ D6N0CY359870244
        Asus G750JX-T4167H
        MB/ G750JW REV. 2.1
        TRY AND REPLAY
        • Newmultifail
          • Dec 2024
          • 5
          • Serbia
          I flashed the edited bios, everything works as it should, now I wait 30 minutes to see if the laptop shuts down.
          Again no serial number in bios but that doesn't matter if everything else is ok
          • Newmultifail
            • Dec 2024
            • 5
            • Serbia
            It works! Just amazing, it didn't shut down after half an hour, thank you very much!
            • mrwab
              Banned
              • Jan 2014
              • 83
              • morocco
              you are welcome
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • flc1988
                asus x510u accelerating fan and after a few minutes it turns off even in bios
                by flc1988
                asus x510u accelerating fan and after a few minutes it turns off even in bios.
                i've tested only motherboard without battery, keyboard, replaced fan, disabled discrete graphics, replaced memories and still shutting down. I am using last bios.
                08-02-2024, 10:16 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
