asus x510u accelerating fan and after a few minutes it turns off even in bios
  • flc1988
    • Nov 2018
    • 11
    • BRAZIL
    asus x510u accelerating fan and after a few minutes it turns off even in bios.
    i've tested only motherboard without battery, keyboard, replaced fan, disabled discrete graphics, replaced memories and still shutting down. I am using last bios.
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    try to request a clean me region bios from you back up
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • Newmultifail
      Asus g750jx Bios turns off after 30 minutes
      by Newmultifail
      I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again?
      I should mention that the bios update did not help.
      backup i sn...
      I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again? I
      12-19-2024, 03:41 PM
