Lenovo Thinkpad P50 Bios Corrupted
  • bannermast
    • Nov 2024
    • 9
    • US
    Hello, it seems to me that my thinkpad P50's BIOS is corrupted. I tried to boot it up and the power button would only blink 3 times green. The serial number is missing from the bottom of the chassis so I'm not sure what to do. I hope it's not the motherboard that's broken...
  • bannermast
    • Nov 2024
    • 9
    • US
    Update: I seem to have made marginal progress. When I boot it without RAM it beeps 1 3 3 1 times, without RAM the fans and keyboard just turn on then off after a few seconds.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12354
      P50 Laptop (ThinkPad) - Type 20EN
      Srial number : PC0EWVAN
      • bannermast
        • Nov 2024
        • 9
        • US
        After replugging the CMOS battery and the switch next to it, I am glad to say that the BIOS file worked. Thank you so much, you just made my day.
        • bannermast
          • Nov 2024
          • 9
          • US
          I've been trying to remove the BIOS Password from my Thinkpad P50, and I have tried to use the autopatcher provided in this forum, however it doesn't seem to work. When I flash the autopatched BIOS to the computer it just beeps 5 times twice then turns off. I've made sure to detach the CMOS battery and held the tamper switch down with tape so I'm not sure what else I can do. One thing I did notice is that when I use my CH341A to verify the hex code for either patched or unpatched BIOSes it seems to mismatch after trying to boot; I assume that's the BIOS self healing? Whenever I flash the original BIOS the computer works as expected. I've attached my original BIOS, the autopatched version, and a screenshot of when I boot with the original BIOS. If anyone could help me out I would greatly appreciate it.
          • peste
            peste commented
            Editing a comment
            post merged..
        • MartyC
          • Jan 2025
          • 5
          Lenovo Thinkpad P50
          Model: 20EQS48H00
          Serial: PC0MLZBV
          Hi, I'm requesting the bios for my P50. I messed up badly after an Ubuntu Studio install/update and now when I hit the power button it just flashes the keyboard lights briefly, and does nothing else. No post, fans or screen. I searched the forum and found other firmware posted, but I'm not sure they're compatible. Thanks for any help!
            • 22024
            Originally posted by MartyC
            Lenovo Thinkpad P50
            Model: 20EQS48H00
            Serial: PC0MLZBV
            Thread merged. Post your bios backup.
            • MartyC
              • Jan 2025
              • 5
              Hi, I'm a complete noob to bios hacking, have just received a CH341A today and will try to extract the corrupted (?) bios tomorrow, hopefully. Will this help?
              • MartyC
                • Jan 2025
                • 5
                Hi again!
                I managed to connect the CH341 and read the bios. Attached is the file.
                • Markus1741
                  • Sep 2020
                  • 958
                  • N/A
                  Hi again!
                  Hello you can try this new file ....
                  • MartyC
                    • Jan 2025
                    • 5
                    Thanks so much! That worked great! Now I have my lappy back. So happy
                    • mouse1972
                      • Jul 2023
                      • 13
                      • Ukraine
                      Hello friends! My P50 does not respond to the power button. It blinks 3 times and nothing happens. I think the problem is in the BIOS. Can someone help me?
                      Type 20EQ
                      Serial MJ-04TPLT
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12354
                        Type 20EQ
                        Serial MJ-04TPLT
                        P50 Laptop (ThinkPad) - Type 20EQ
                        • mouse1972
                          • Jul 2023
                          • 13
                          • Ukraine
                          Rewrote the bios, but nothing changed. The power button blinks 3 times after pressing and nothing happens
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12354
                            Check hardware
                            • mouse1972
                              • Jul 2023
                              • 13
                              • Ukraine
                              Before reflashing it was 100% working laptop😭
                              • Markus1741
                                • Sep 2020
                                • 958
                                • N/A
                                Hello you can try this files ma be it helps good luck ....
                                • mouse1972
                                  • Jul 2023
                                  • 13
                                  • Ukraine
                                  Thanks for your help. Everything worked. The laptop came to life and even works normally. I hope this will last for a long time.
                                  • yassin1913
                                    • Feb 2015
                                    • 29
                                    • maroc
                                    Hellooo can someone please help fix this corrupted bios..When I boot it without RAM it beeps 1 3 3 1 times
                                    type 20FK
                                    SN>R9-0N3K6A 17/03
                                    • yassin1913
                                      • Feb 2015
                                      • 29
                                      • maroc
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        08-12-2025, 03:01 PM
                                      • to5it0
                                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                        by to5it0
                                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                        I have opened the laptop and identified the main BIOS chip...
                                        10-24-2025, 01:35 AM
                                        Lenovo ThinkPad P50s Ultrabook P Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad P50s Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P50s boardview and P50s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                        09-06-2024, 06:58 AM
                                        Lenovo ThinkPad P50s Mobile workstation P Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad P50s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P50s boardview and P50s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                        09-06-2024, 06:00 AM
                                        09-06-2024, 05:54 AM
