latest ME region BIOS update hp 440 g3
  • jeffer dacon
    • May 2022
    • 35
    • colombia
    Hi guys, could you update the ME region of this HP 440 G3 BIOS? I have cleared the Me region but it still doesn't work, thanks
  • LiLJC408
    • Nov 2022
    • 11
    Try this
    • peste
      peste commented
      Editing a comment
      It doesn't help if you don't follow the forum rules.
  • jeffer dacon
    • May 2022
    • 35
    • colombia
    thank you
    • peste
      • Dec 2016
      • 13739
      • ROMANIA
      post the S/N, the motherboard model, etc.
      • jeffer dacon
        • May 2022
        • 35
        • colombia
        SN: 5CD6043VM8
        I already reprogrammed with the bios that they published but a warning appears "warning the machine is not in confirmation state" I deactivated the secure boot but it does not load, the system turns on and off.​
        • jeffer dacon
          • May 2022
          • 35
          • colombia
          Originally posted by LiLJC408
          Try this
          Hello friend, I programmed the bios and it gave me an image but I got an alert "warning machine is not in committed state"
          I don't know how to solve it. I was trying to solve it with Intel System Me Tool but I haven't been able to.
          model: HP 440 G3 DAX61CMB6D1 REV D
          SN: 5CD6043VM8
            • 22097
            SN: 5CD6043VM8​
            The original bios has Consumer ME firmware. Use Consumer not Corporate firmware.
            • LiLJC408
              • Nov 2022
              • 11
              SN: 5CD6043VM8
              Hi, try this file. Here is your DMI in case you need to program in BIOS.
              SerialNumber:5CD6043VM8
              ProductConfigurationID:L6D82AV
              Board CT Number:PFMKH058J9Z149
              ProductName:HP ProBook 430 G3
              BuildID:15WWR4BW601#SUUW#DUUW
              FeatureByte:3X47676J6S6Z6b7J7M7Q7W7saBapaqawbhcAdUeh.3A
              • jeffer dacon
                • May 2022
                • 35
                • colombia
                thank you bro , The "warnin machine..." alert keeps appearing but if you let me install the system, thank you very much
                • mikeybass
                  by mikeybass
                  04-23-2025, 04:30 PM
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • al3m0di
                  Update bios EFCN58WW to EFCN59WW
                  by al3m0di
                  Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                  I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                  The BIOS version is EFCN58WW.
                  When I turn on the device, it displays the message:
                  "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                  The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                  I've tried
                  07-29-2024, 10:32 AM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • 0xx
                  2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                  by 0xx
                  Hi folks,
                  My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                  What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                  I assumed that Windows Update was interrupted due to closing...
                  09-14-2025, 03:46 PM
