latest ME region BIOS update hp 440 g3
  • jeffer dacon
    • May 2022
    • 35
    • colombia
    Hi guys, could you update the ME region of this HP 440 G3 BIOS? I have cleared the Me region but it still doesn't work, thanks
  • LiLJC408
    • Nov 2022
    • 10
    Try this
    • peste
      peste commented
      Editing a comment
      It doesn't help if you don't follow the forum rules.
  • jeffer dacon
    • May 2022
    • 35
    • colombia
    thank you
    • peste
      • 13258
      • ROMANIA
      post the S/N, the motherboard model, etc.
      • jeffer dacon
        • May 2022
        • 35
        • colombia
        SN: 5CD6043VM8
        I already reprogrammed with the bios that they published but a warning appears "warning the machine is not in confirmation state" I deactivated the secure boot but it does not load, the system turns on and off.​
        • jeffer dacon
          • May 2022
          • 35
          • colombia
          Originally posted by LiLJC408
          Try this
          Hello friend, I programmed the bios and it gave me an image but I got an alert "warning machine is not in committed state"
          I don't know how to solve it. I was trying to solve it with Intel System Me Tool but I haven't been able to.
          model: HP 440 G3 DAX61CMB6D1 REV D
          SN: 5CD6043VM8
            • 21517
            SN: 5CD6043VM8​
            The original bios has Consumer ME firmware. Use Consumer not Corporate firmware.
            • LiLJC408
              • Nov 2022
              • 10
              SN: 5CD6043VM8
              Hi, try this file. Here is your DMI in case you need to program in BIOS.
              SerialNumber:5CD6043VM8
              ProductConfigurationID:L6D82AV
              Board CT Number:PFMKH058J9Z149
              ProductName:HP ProBook 430 G3
              BuildID:15WWR4BW601#SUUW#DUUW
              FeatureByte:3X47676J6S6Z6b7J7M7Q7W7saBapaqawbhcAdUeh.3A
              • jeffer dacon
                • May 2022
                • 35
                • colombia
                thank you bro , The "warnin machine..." alert keeps appearing but if you let me install the system, thank you very much
                • mikeybass
                  by mikeybass
                  04-23-2025, 04:30 PM
                • al3m0di
                  Update bios EFCN58WW to EFCN59WW
                  by al3m0di
                  Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                  I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                  The BIOS version is EFCN58WW.
                  When I turn on the device, it displays the message:
                  "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                  The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                  I've tried
                  07-29-2024, 10:32 AM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • 0xx
                  2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                  by 0xx
                  Hi folks,
                  My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                  What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                  I assumed that Windows Update was interrupted due to closing...
                  09-14-2025, 03:46 PM
                • iZakre
                  HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                  by iZakre
                  Hello everybody!
                  To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                  The thing is that I had installed TeamViewer and could log into the computer...
                  02-19-2023, 02:27 PM
