request HP Probook 4530s bios dump
  • hat7et
    • Aug 2021
    • 4
    • Egypt
    #61
    Re: request HP Probook 4530s bios dump
    Originally posted by Schtekker
    tested
    this file size is 4097
    the original one is 4096
    • Noreddin
      • Jan 2020
      • 73
      • mostaganem
      #62
      Thank you
      thanks
      • Kashi1712
        • Jan 2017
        • 73
        • Belgium
        #63
        Can I ask to remove the BIOS password? (see attached zip)
        Did completely forget the password of the laptop...
        Thanks!
          • 22286
          Thanks!
          Try HPUnlocker and RCUnlocker https://www.badcaps.net/forum/showthread.php?t=103570
          • Kashi1712
            • Jan 2017
            • 73
            • Belgium
            #65
            Originally posted by SMDFlea
            Hey !
            Will give it a try, thanks !
            • Kashi1712
              • Jan 2017
              • 73
              • Belgium
              #66
              Works perfectly fine ! Thanks !
              • yotoprules
                • Feb 2022
                • 3
                • England
                #67
                Thank you so much, was able to recover my bricked 4530s using CH341a.
                • charif
                  • Feb 2016
                  • 30
                  • agad
                  #68
                  password bin HP Probook 4530s
                  Please, I would like to get the bios file without a password
                    • 22286
                    Re: password bin HP Probook 4530s
                    See post #64
                    • Jovica123
                      • Oct 2017
                      • 84
                      • N/A
                      #70
                      HP Probook 4530s
                      Hello
                      Can someone copy data (product number,serial number..etc) from original bin file to bin file "ramones" ?
                      I will post picture from all data also.
                      Thank you !
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12441
                        #71
                        Re: HP Probook 4530s
                        Originally posted by Jovica123
                        Hello
                        Thank you !
                        Try
                        • GREAT_MERA
                          • Jul 2021
                          • 17
                          • sri lanka
                          #72
                          it says file size larger than the ic size.. what the issue ..
                          • tito01480
                            • Jun 2024
                            • 3
                            • France
                            #73
                            HP 4530S CNU1261RSG LH297EA#ABF
                            Hi here,
                            I forgot my admin bios password a long time ago, and it seems we can erase it.
                            if some can give a hand
                            Description and original dump
                            serial CNU1261RSG
                            Sku LH297EA#ABF
                            Sysbrdct PCCAF00QE0X4WO
                            uuid B523901CAA7FE01190EF30097F190006
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12441
                              #74
                              Hi here,
                              serial CNU1261RSG
                              Sku LH297EA#ABF
                              Try
                              • ansen43
                                • May 2013
                                • 8
                                • ireland
                                #75
                                tested
                                worked for me. thanks a lot.
                                • Buzzfuzz2k
                                  Bios password removal on a Unowhy dump
                                  by Buzzfuzz2k
                                  Hi Everyone,
                                  I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                  The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                  the Computer is a Unowhy small pc
                                  N° UYM6524702229
                                  After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                  My first attempt was to get the bios dump from windows...
                                  11-13-2023, 07:37 AM
                                • dell_bios
                                  Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
                                  by dell_bios
                                  I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
                                  The board has three SPI flash chips:
                                  - W25Q64FV (main BIOS)
                                  - W25Q32FV (EC/TPM)
                                  - W25X10CL (configuration)
                                  I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
                                  The dump contains protection that needs to be removed.
                                  If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
                                  I’m also happy to share my dump for comparison if needed.
                                  Laptop model: [please specify, e.g....
                                  10-16-2025, 04:28 PM
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • traxformania
                                  TONGFANG "GM7TG7P" Bios Password Problem?
                                  by traxformania
                                  I tried :
                                  -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                  11-15-2023, 07:32 AM
                                • Soumana Sanou
                                  “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                  by Soumana Sanou
                                  Hello,😇😇😇
                                  I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                  🔧 Model: HP ProBook 11 G2
                                  📦 Serial Number: 8CG72478MY
                                  🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                  🔒 BIOS Status: Locked with password
                                  The laptop is no longer under warranty and HP refused to help me.
                                  I’m looking for a custom SMC.bin file.
                                  I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                  Thanks a lot for your help!🙏🙏🙏...
                                  06-17-2025, 04:04 PM
