Gigabyte AORUS 7 9K Need bios laptop - Black Screen
  • mavaro
    • May 2017
    • 30
    • Polska
    I have a laptop Gigabyte AORUS 7 9KF and I need a bios for it, It starts without an image, stops at 0.6A. Motherboard: Gigabyte GA-X7E rev. 1:0
  • peste
    • Dec 2016
    • 13678
    • ROMANIA
    post the S/N, etc.
    • mavaro
      • May 2017
      • 30
      • Polska
      Originally posted by peste
      post the S/N, etc.
      Serial number laptop: SN23190J000254
      • volinakis
        • Jan 2021
        • 2874
        • N/A
        Try
        • pahahi
          • Aug 2017
          • 7
          • germany
          I have a laptop Gigabyte AORUS 7 9KF and I need a bios for it, It starts with black screen, stops at 0.12A.
          SN: SN24060J000251
          thanks
          • peste
            peste commented
            Editing a comment
            post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
        • Bloodhoundje
          HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
          by Bloodhoundje
          I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
          I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
          After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
          I have desoldered the bios chip (GigaDevice...
          03-16-2024, 03:12 PM
        • JoWed
          Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
          by JoWed
          Hello Community,
          I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
          07-01-2025, 09:32 AM
        • Technodoc
          ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
          by Technodoc
          Asus laptop G614JZ-N3012W Rog Strix with i7
          Mainboard G634J-PMV-VGT
          6050A3441302-MB-A01
          2023-02-10
          Power button works okay....power light goes on
          Red "bottom" leds go on
          Charging led works
          Fans do not spin, capslock key does nothing, screen stays black
          I would like to program the bios again, to rule out a corrupted bios.
          However I run into a size error
          The bios chip is a Winbond 25R256JVEN
          Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
          02-24-2025, 04:46 AM
        • legendkray
          BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
          by legendkray
          I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
          07-05-2025, 09:25 AM
        • sect-sin
          Gigabyte XT 6800 XT Aorus Master BIOS needed
          by sect-sin
          I have an AORUS MASTER RX 6800 XT (non USB-C version), and my problem is that FUSION RGB is not working, it is not finding the GPU, and the RGB lights are off. There is a new firmware on the Gigabyte site which is supposed to fix this exact issue, but their Firmware upgrade does not work (I just get the highly unhelpful Erasing Flash Failed message when trying to update). I tried various internet-recommended software fixes to address this, but nothing helped, the factory Gigabyte EXE refuses to flash the BIOS.
          My last resort would really be flashing the...
          10-13-2023, 06:08 AM
