MS-15451 BIOS dump
  • Jackal28
    • Sep 2024
    • 6
    MS-15451 BIOS dump
    Yep, I'm there right now. Just need to find a MS-15451 BIOS dump...help please. I bought 2 bios chips when I could (always leave an extra for mistakes). Also from alien press. That's the only place I've ever been able to find chips that are hard to find. I managed to pick up 2 different (4 total) MOST communication chips for Audi/ Mercedes optical transfers.
    • 22286
    Please post the full laptop model number, and type and post the laptop serial number.
    • Jackal28
      • Sep 2024
      • 6
      didn't leave enough info. Sorry, I just thought it was generic file dump. Especially since MSI uses a base identical bios for countless forms of their gaming laptops. What I'm looking for involves:
      Raider GE67HX 12UGS-013US-GB71280X16GXXDX11PK2207N0017083
      11-01-2023 purchased January
      If you or anyone finds anything, I'd appreciate it. I just received two exact replacement chips. I broke the original one being too hastey.
      • volinakis
        • Jan 2021
        • 2877
        • N/A
        bios file is on their website, you just have to chose your model, download and unpack. Change extension from .10D to .bin and voila!
Name:	Screen Shot 2024-11-04 at 09.35.05.png
        • Jackal28
          • Sep 2024
          • 6
          Thats awesome. I will give it a try. Im sure I can install it on the chip. Installing the chip on the motherboard. Ehhhhhhhh? Checking for schematics now given that the pads were destroyed by a hastey engineer...ME
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • haitham sharabati
            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
            by haitham sharabati
            Hello engineers 😀,
            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
            💀 Problem:😅
            - Device shows “Administrator Password”...
            08-07-2025, 04:54 AM
