HP factory bios patcher
  • b4rdock
    • Jun 2017
    • 105
    • usa
    for example i run one by one script 1..2...3 etc the script modidy the locked.bin then save , i need run always and save the changes in all script or just in one if this modify the locked file ?
    regards
      SMDFlea commented
      Editing a comment
      If any changes are made save before going to the next script. If an error happens no changes are made, just go onto the next script
  • ingenieroedu
    • May 2023
    • 76
    • Colombia
    I have performed all the steps and tried several times, changing the name only to locked without the .bin, I tried all the scripts, none of them work.
      • 21690
      You havn`t posted any information, nothing, can`t help you without that..
      • ingenieroedu
        • May 2023
        • 76
        • Colombia
        You're right, when I published it seems there was some kind of damage since it didn't finish uploading the information.
        Last edited by ingenieroedu; 06-14-2025, 01:25 PM. Reason: the attachment did not load
          • 21690
          did you copy your main bios into the DMICOPY folder, and rename it to locked.bin (with only 1 file extension .bin ,not .bin.bin) .If the full script doesn`t work try the seperate ones. Which model is it etc ?
          • alexlenz
            • Feb 2023
            • 9
            • Brazil
            #26
            Originally posted by santoslao
            I tested this on a 640 g9 bios version U75 and it didn't work. It makes the corrections and at the end in tiny hexer a last message appears as in the down image. I save the file and then flash it on the machine, but at startup it still asks for the password. I think you need to correct something else within the patch file and the program doesn't do it, according to another comparison of unlocked files that I see.
            Click image for larger version Name:	Screenshot_1.png Views:	0 Size:	71.3 KB ID:	3568120
            Hi, did you manage to get the patch working on the HP 640 G9?
            • leeaustiner
              • Sep 2025
              • PHILIPPINES
              #27
              you dont need to reflash the BIOS to remove the password? you just need to patch ur own bios?
              • thesame
                • Mar 2018
                • 139
                • Romania
                #28
                Has anyone managed to unlock HP Elite Mini 600 G9 with the scripts?
                  • 21690
                  The scripts only work with old G9 bios versions.
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • Wahaz
                    by Wahaz
                    10-30-2023, 08:42 PM
                  • lucaszmn
                    by lucaszmn
                    Problem:
                    Initial Findings:
                    • I concluded that the
                    08-12-2025, 03:01 PM
