thinkpad L14 GEN 3 with bios password
    Hi sir
    i have thinkpad L14 Gen 3 with bios password
    password in super I/O NPCX977
    I need a way to take backup EC (NPCX977) or another way to bypass
    SN PW-04K75W
    TYPE 21C2-S3QF01
    hi sir
    @Maxpower3
    i have thinkpad L14 Gen 3 intel i5 NPCX977
    I tried your way in the video thinkpad p17
    The device does not enter in the BIOS
      SMDFlea commented
      Editing a comment
      posts moved from EC bypass topic to the thread topic you started months ago..
    Originally posted by volcour View Post
    hi sir
    @Maxpower3
    Give the dump file!
    serial number and others to comply with the rules
      Originally posted by Maxpower3 View Post
      Give the dump file!
      EC (NPCX977)
      SN PW-04K75W
      TYPE 21C2-S3QF01
        try
        you should also have put your file unlock to compare
          Hi sir
          SN PW-04K75W
          TYPE 21C2-S3QF01
          Finally I read EC NPCX977 please help me
            try
            OK thank you
              try
              same problem
                why do I have 2 different files?
                have you reread the original?
                parts are missing since write problem .
                try mod
                you forgot something
                  try mod
                  The original file was uploaded and the second one was uploaded after the problem occurred.
                    unlock ioriginal, t"s same of l14 gen 3 unock
                    retry .
                    if not work .put back the original and look if error comes?
                    there are lots of pieces everywhere. why L14/15 are always boring
                      retry .
                      After restoring the original file it works
                      It's confusing
                        The problem solved after extracting EC from EXE file
                          I will tell you my "adventure" with L14 gen 3 intel: I had 3 pcs, 1st I read SIO without main battery and CMOS batt and all went well, no errors, SVP removed.
Name:	Screen Shot 2025-03-13 at 20.05.23.png
                          At 2nd, being lazy I just removed keyboard to connect SVOD4 (without removing battery and CMOS batt), read SIO, filled same area with 00 and surprise! password still there! I did read again SIO and compared with original backup and noticed that something similar with strings I filled with 00 is starting with adress 3FC62 but it wasn't in original backup. After I filled that section with 00 password was gone! Bottom line, must read SIO without battery and CMOS batt.
Name:	Screen Shot 2025-03-13 at 20.18.09.png
                            Thank you so much for sharing this information
                              how to read NPCX977 by using svod via keyboard?
