BIOS REQUEST FOR ASUS G713Q
  • GB1999
    • Mar 2023
    • 71
    • Malaysia
    ASUS G713Q-RK4168T
    SN: MBNRKD00852546E
    PROBLEM STUCK ON LOGO
    THANKS IN ADVANCE
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • skurvysyn
    BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
    by skurvysyn
    laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
    original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
    01-08-2025, 04:45 PM
  • skipron.rm
    ASUS Zephyrus GX701LXS BIOS request
    by skipron.rm
    Hello everyone, trust you're doing well.
    I'm currently facing an issue with my ASUS Zephyrus GX701LXS, as it isn't posting.
    I've downloaded the latest BIOS version, "GX701LXS-AS.311" (v.311), from the ASUS website.
    However, there's a challenge – the file size exceeds the capacity of the BIOS chip, making it impractical for writing.
    The current BIOS dump ("GX701LXS.307 bios-dump.bin" find attached), is of version 307.
    My attempt to extract "GX701LXS-AS.311" using the "AMI_BIOS_GUARD_Extractor" was aimed at combining...
    Badcaps - Capacitor Search Engine & Electronics Repair Forum
    12-11-2023, 06:12 PM
