Want to confirm it's not a problem with BIOS first.
Need [BIOS dump] for a DA0HK6MB6G0 or MBX-268 Rev. G (SVE14125CLB)
Tags: None
Re: Need [BIOS dump] for a DA0HK6MB6G0 or MBX-268 Rev. G (SVE14125CLB)
here:
tested okAttached Files -
i can't not read this file after extractedComment
Hello dj_ricoh, I don't remember, I solved it a long time ago, thanks for the concern though.Comment
that's why I ask. ofc I don`t have bga station to reball the chipset. I only did a reflow but nothing. the weird problem is that its showing that its almost starting. bios crystal fets SIO everything show that almost start but something its shuting it downJust cook it! It's already broken.Comment
dj> just check for short on powerswitched rails and u will find your problemComment
what do you mean powerswitched rails? a hint? should I take coils down and see where is the short?
if you manage to fix one, a good hint will be to tell me what did you find bad in yours!Last edited by dj_ricoh; 06-28-2014, 01:11 AM.Just cook it! It's already broken.Comment
just check for shorts on big coils. mostly it is bad chip. after unsolder coil u will be for sure which side is shorted. next unsolder chip and chceck for short on pins.Comment
I'm sorry, but I don't really remember, anything I do over 2 days is out of my mind.Comment
Hello, i have a question... i´m new flashing bios and i see that the size of the rom is 8.4mb while the bios chip capacity is 8mb, i understand de this file contains the bios and ec data? hod do i split it so i can copy only the bios? best regards!Comment
MBX-268 with DDR will shutdown after 1 to 2 seconds. no DDR will not shutdown. I've reball HM. but the situation has not changedComment
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by grimacelordThis laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
Motherboard model number: DA0PAMB46A1 REV: A
Secondary motherboard model number: 0PAB
SKU: 685K4UA
Serial number is: 5CD3223BJP
Recently reflashed this laptop with latest BIOS and once...-
Channel: BIOS Requests ONLY!
by DynaxSCHi,
I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...-
11-06-2022, 05:22 PM -
by vinaypundithI have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
So, I'm looking for a BIOS dump for this machine - a 16MB one....-
- Loading...
