ASUS X412U BIOS help
  • KABY
    • Dec 2022
    • 71
    • algeria
    hellow i have asus X412U BIOS LOCKED
    can someone help me to remove it plz
    fon sn and tag i dont have them the ticket on the laptop removed
  • peste
    • Dec 2016
    • 12792
    • ROMANIA
    post the S/N,the motherboard model, etc.
    • KABY
      • Dec 2022
      • 71
      • algeria
      This is the only informations I have
      I don't know if SN began from 24M... or the other lines
      motherboard is x412uf rev 2.1​
        • 20888
        24M is the length of the warranty in months, the next line is the serial number, the last line is the manufacturing date.
        • KABY
          • Dec 2022
          • 71
          • algeria
          Thank u for the informations
          • KABY
            • Dec 2022
            • 71
            • algeria
            Do you want further informations sir
            thank u for reply 😊
            • volinakis
              • Jan 2021
              • 2733
              • N/A
              thank u for reply 😊
              WRITE serial number, as in RULES!
              then, try this passwords:
              Qrzq (or Arza, if you have french keyboard)
              0407
              (US keyboard)
              • KABY
                • Dec 2022
                • 71
                • algeria
                0407
                (US keyboard)
                Serial number is K8N0CV10V56034C
                for the solution you propose it's not working for me 😔
                • KABY
                  • Dec 2022
                  • 71
                  • algeria
                  Update
                  0407 it's working thank u sir
                  • KABY
                    • Dec 2022
                    • 71
                    • algeria
                    0407
                    (US keyboard)
                    Hello sir the last method works but now it's not
                    I have done reste to the bios and now the password it's incorrect can u help me with the bios and remove it completely
                    every time I turn it on the bios password request shows
                    Thank you
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11733
                      Thank you
                      Password removed
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • grimacelord
                        by grimacelord
                        07-10-2025, 02:52 PM
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • lrouw84
                        by lrouw84
                        Hi there,
                        01-28-2023, 01:31 PM
