ASUS UP6502ZD not turning ON with AC Power
  • mferna14
    • Jun 2018
    • 1046
    Hi friends., working on Intel 12th Gen ASUS UP6502ZD. I think I am the 1st trouble-shooting post for this model.. The laptop turns on fine with main battery but the SSD gives read errors, does not boot to Windows. With the USB-C AC power connector plugged in it does not turn on at all. 3.3v & 5v both present. There is 3.2 volts on the power switch. I think that a cleanup of the BIOS will clear this problem, attached is the Original BIOS Bin file. Kindly if anyone could re-do this BIOS Bin file, I would appreciate.
    Motherboard Model: UP6502ZD R2.0 Laptop Serial #: R1N0CV06A23202A​
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Can you take a barcode image in the back of cover
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
ID:	3336686​its showing UP6502ZA
      • mferna14
        • Jun 2018
        • 1046
        Thanks Brother kalilinux25 for helping me. The photo which is at the back is a QR code. hope this helps. Kindly edit BIOS if you can.
        Click image for larger version  Name:	IMG_7416.jpg Views:	0 Size:	829.0 KB ID:	3337829
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          Try this one brother I dint have the tools to clean me region this file but please do try and give feed back, its a fresh bin file and add your dmi . NOT CLEAN ME REGION
          Click image for larger version  Name:	image.png Views:	0 Size:	8.3 KB ID:	3338002
          • mferna14
            • Jun 2018
            • 1046
            Dear kalilinux25​ your edited BIOS works 100% fine. Same problem, there is something wrong with the main motherboard. Have to trouble shoot this problem. Thanks dear for all the help. Hope this edited BIOS for this model will even help someone else. Thanks
            • tktrom
              • Jul 2022
              • 80
              • Bolivia
              Good afternoon, I have this BIOS that does not turn on the machine. I tried another BIOS from this thread with the machine turns on but does not recognize the M.2 disk.
              model: Q569Z
              S/N : NAN0CV10H294438
              Mainboard: UP6502ZD
              • tuyen821991
                • Oct 2024
                • 50
                • Viet Nam
                model: Q569Z
                Mainboard: UP6502ZD
                try
                • tktrom
                  • Jul 2022
                  • 80
                  • Bolivia
                  Originally posted by tuyen821991
                  try
                  Thank you very much, perfect job.
                  • uranus
                    Just a humanoid
                    • Sep 2014
                    • 26
                    • Israel
                    Hello all
                    Not turning on, no shortage, all power rails are ok, i see the on oscilloscope EC pulse on BIOS for a sec or so...
                    but nothing happens, probably corrupted bios
                    kindly appreciated if someone can check it or rebuild if possible
                    Asus Q539Z
                    MB: UP6502ZD rev 2.0
                    SN: N6N0CV07R22624A
                    • tuyen821991
                      • Oct 2024
                      • 50
                      • Viet Nam
                      Originally posted by uranus
                      Hello all
                      Asus Q539Z
                      SN: N6N0CV07R22624A
                      try it
                      • uranus
                        Just a humanoid
                        • Sep 2014
                        • 26
                        • Israel
                        try it
                        tried, still have a power issue, need to dive deeper
                        thanks for the efforts
                        • BOGOSY77
                          • Aug 2018
                          • 59
                          • PITON
                          Hello
                          facing same problem now, did you find the fix?
                          • BOGOSY77
                            • Aug 2018
                            • 59
                            • PITON
                            Hello
                            sorry I miss button for flag or replying
                            • mferna14
                              • Jun 2018
                              • 1046
                              Originally posted by BOGOSY77
                              Hello
                              This is a BIOS post, kindly post in a separate trouble shooting thread, I might be able to help you out there. Thanks dear for your understanding.
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • ShadowAi
                                ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                by ShadowAi
                                Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                03-15-2024, 10:46 AM
                              • conghuyms
                                Request for Help – ASUS G531GW Rev 1.6 – No Power On
                                by conghuyms
                                I need your support with an ASUS G531GW Rev 1.6 laptop.
                                When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
                                Here’s what I’ve checked so far:
                                • Motherboard has been removed for inspection.
                                • 3V and 5V always-on rails are present (3V/5V_ALW).
                                • 1.8V and 1.09V at the PCH are present.
                                • I don’t have the boardview/schematic, so troubleshooting is limited.
                                • I tried checking the power button signal from the
                                07-20-2025, 09:14 PM
                              • Duranitron
                                Asus x512dk rev 2.1 power on problem
                                by Duranitron
                                When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                11-26-2024, 10:22 PM
                              • Thomas Smith
                                Asus Tuf gaming fx506l no power, mosfet does not open
                                by Thomas Smith
                                Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
                                Initial Symptoms:
                                • The laptop has no power at all (no LEDs, no fan spin).
                                • No 3.3V or 5V present on the board.
                                • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
                                Power Rail Checks:
                                1. Charger input (FETs PKCH2BB)
                                  • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
                                2. BQ24780S Charger IC:
                                  • VCC and ACDET are present.
                                  • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
                                  • Shunt resistor has 10Ω to ground.
                                03-30-2025, 03:38 AM
