Bios dell latitude 5450 intel ultra 5 135u need build
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    #81
    Advice for the person that have RT809F
    when you read a chip that isn`t supported choose a different chip with 512 capacity
    use W25Q512NW that support 1.8v ...no 1.8V adapter is needed ....ignore check-ID
    Thank you SMDFlea for your help
    • BGinvestments
      • Jan 2024
      • 21
      • Colombia
      #82
      hi, Please help me to unlock this bios.
      Model: Dell Latitude 5450
      ST: BRC9SW3
      • hoaca388
        Badcaps
        • Jan 2022
        • 12325
        #83
        ST: BRC9SW3
        Backup fault.
        ​https://www.badcaps.net/donate
        • ymifdal
          • Jan 2022
          • 120
          • Morocco
          #84
          Any solution to this fellas?
          It's a 25LR512MEYIG and that's the Vcc Pin I guess
          I just wanna be able to read the chip to post here along with ST and the other info
          • ymifdal
            • Jan 2022
            • 120
            • Morocco
            #85
            I guess I'ma just try to decap the chip tomorrow and look for the internal VCC pad lol
            I’ve done this before on other damaged chips that come damaged but never did a WSON8
            • vidvansh
              • Mar 2025
              • 26
              I has the same issue with the same chip. i think they purposely build it this way so no one can work on it.
              I has to buy new chip to make it work
              • ymifdal
                • Jan 2022
                • 120
                • Morocco
                #87
                Yes they're making it kinda hard to remove by placing the ic in some tough places
                I did order another IC too I'll just try to build a new bios by then since I can no longer read the old chip
                • fricosu007
                  • Feb 2016
                  • 35
                  • romania
                  #88
                  could you help with a locked Dell Latitude 5450
                  Reg. Model : P165G
                  board id "
                  JDB41 LA-N381P
                  rev 1 - 2023-12-18
                  Ultra 5 / 16gb ddr5 / 512 ssd
                  MFGYR:2024
                  ST:JCH6Q34
                  read dump with REVELPROG IS x3
                  eeprom ic: Winbond 25R512NWEQ
                  dump posted as 20251002_101917_W25Q512NW.RAR
                  • peste
                    • Dec 2016
                    • 13573
                    • ROMANIA
                    #89
                    Reg. Model : P165G
                    board id "
                    JDB41 LA-N381P
                    rev 1 - 2023-12-18
                    MFGYR:2024
                    ST:JCH6Q34
                    try...
                    • fricosu007
                      • Feb 2016
                      • 35
                      • romania
                      #90
                      Originally posted by peste
                      try...
                      Merci frumos ! Thks A LOT ! i will test it right now ...
                      try...
                      Thanks ! its fine, working as new ! many thanks !
                      • appie1206
                        • Oct 2016
                        • 127
                        • netherlands
                        #91
                        Can someone clean this one for me need too be unlock!
                        servicetag :6Q2Q444
                        • peste
                          • Dec 2016
                          • 13573
                          • ROMANIA
                          #92
                          servicetag :6Q2Q444
                          this is not the bios it is looking for a W25Q512 chip
                          • appie1206
                            • Oct 2016
                            • 127
                            • netherlands
                            #93
                            wich one it is? the giga device... mine reader wont read it
                            • appie1206
                              • Oct 2016
                              • 127
                              • netherlands
                              #94
                              Think is this one but it is broken i think it wont read the size ...
                                • 21853
                                What model is your programmer and the software version
                                • appie1206
                                  • Oct 2016
                                  • 127
                                  • netherlands
                                  #96
                                  i have a Svod 3 programmer ... it regconize the brand... but no size of the file shown.. is see also error unknown type flash
                                  software version ver 1.1.2.8
                                  • appie1206
                                    • Oct 2016
                                    • 127
                                    • netherlands
                                    #97
                                    servicetag :6Q2Q444
                                    this is the good one!
                                      • 21853
                                      servicetag :6Q2Q444
                                      It`s only read 64KB .I don`t have a SVOD programmer so i can`t advise what the settings should be.Do you have a CH341A or another programmer to make the backup with
                                      • appie1206
                                        • Oct 2016
                                        • 127
                                        • netherlands
                                        #99
                                        Yes i also have that one.... how must i set the settings too read and save the file?
                                          • 21853
                                          what is the bios chip part number
                                          • Julian Bailey
                                            Dell Latitude 5350 Ultra 7 Motherboard
                                            by Julian Bailey
                                            Hi
                                            I have a Dell Latitude 5350 Ultra 7 Motherboard I am trying to repair that has a blown chip.
                                            The chip is marked as eHOLH similar to the one I have pictured.
                                            Any ideas what it does and what the pin outs are as 3 tracks have gone and need to find out what / where they went / did etc.
                                            Dell PN of the motherboard is 08DCGW.
                                            Below is the area I am trying to repair:
                                            Does anyone have a picture of this motherboard in this area they could take and upload?
                                            Cheers...
                                            07-03-2025, 11:25 PM
                                          • Dobrowol
                                            Dell Latitude 3520 help with bios build/repair
                                            by Dobrowol
                                            Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                                            Steps i done and results:
                                            I exported a clean bios from update file via pfs extract.
                                            1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                                            Result: Dead
                                            2. Build clean bios with no changes in ME, new PMC, PCH
                                            Result: Dead
                                            3. Build old bios with clean ME, new PMC, PCH
                                            Result: The same
                                            09-22-2023, 02:43 AM
                                            LG Gram Ultra-Lightweight Notebook Specification for Upgrade or Repair
                                            This specification for the LG Gram Ultra-Lightweight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Lightweight boardview and Ultra-Lightweight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 03:40 AM
