huawei nbl-wap9r
  • reset1986
    • Dec 2014
    • 308
    • italia
    huawei nbl-wap9r
    Hi, I have this Huawei which shows a black screen when turned on, I need a working bios, the original backup is attached
    mainboard ryzen 7
    model huawei nbl-wap9r
    dah98ambad0 rev d
    sn/ g2qpm20b18001553
  • volinakis
    • Jan 2021
    • 2733
    • N/A
    mainboard ryzen 7
    dah98ambad0 rev d
    try
    • reset1986
      • Dec 2014
      • 308
      • italia
      Originally posted by volinakis
      try
      I wrote the bios, screen still black, the fan doesn't turn, I noticed that after 15 seconds the laptop restarts, and the LED near the connector flashes quickly, solutions?the chip is a windond 25q64FW
      • volinakis
        • Jan 2021
        • 2733
        • N/A
        bios is extracted from update and transferred your DMI. Check soldering and let it run for 2 minutes to load new settings
        • reset1986
          • Dec 2014
          • 308
          • italia
          once this is done the situation does not change, I carried out some measurements and I find pin 8 of the 25q64fw at around 3 ohms, it seems too little, I desoldered the chip and injected 1.8v on pin 8 and it consumes around 1.4A and I find that the cpu heats up, I think the CPU is damaged, opinions?
          • volinakis
            • Jan 2021
            • 2733
            • N/A
            remove bios chipset and see if it's not damaged (impedance to pin 8 pad should be >3ohm, also check diode to pin 8 pad) take a photo with bios chipset and components around it.
            • reset1986
              • Dec 2014
              • 308
              • italia
              Thanks for the help, but I delivered it to the customer unrepairable
