Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Huawei matte DAH98AMBAD0 search EC file
  • PacoGT
    • Sep 2022
    • 141
    • Guatemala
    Hi, I'm looking for a copy of the EC chip. I replaced it on a motherboard that had the EC chip, but it seems the first one in the laptop was programmable. It overheated, and even after replacing it, it still won't turn on. I suppose it needs to be programmed.
    I've already searched on Google and this forum, but I haven't found a copy of the EC chip. If nobody has it, I suppose I'll have to buy it on eBay or AliExpress, since I saw that they sell this chip already programmed there.
    this ec ITB987VG
    • 23049
    this ec ITB987VG
    Type the laptop serial number, full name and model, motherboard model, etc.
    post the contents of the bios chip ,we might be able to extract the EC from it
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    Badcaps relies on your donations to pay for hosting , site advertising goes nowhere near to covering these costs. If you have found my reply or post helpful please consider making a donation , thank you.
    • PacoGT
      • Sep 2022
      • 141
      • Guatemala
      HUAWEI MateBook
      motherboard DAH98AMBAD0
      ID 2019ap8010
      model nbl-qaq9r​
      • m1ch43lzm
        • Mar 2019
        • 1573
        • Peru
        S/N M6TPM20615001566
        Try, EC extracted from your BIOS backup, cut to 128KB
        • PacoGT
          • Sep 2022
          • 141
          • Guatemala
          thanks i test and reply
          • maanee11
            Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
            by maanee11
            Hello Everyone,
            I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
            It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
            In the website, you can only see specs etc.
            I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
            11-08-2025, 04:08 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • ChrisLannie15
            Huawei Matebook D 15 2021 Intel bios bin/file
            by ChrisLannie15
            Hello is there anyone that has bios bin/file for Huawei Laptop
            It's cpu is Intel core i3 10th generation 8gb ram.
            MB Model: dah98mb38b0 rev b hf
            MB: H98
            BOB-WAI9 Model number
            I don't have the serial number cause the sticker got scratched but here's my backup bin.
            Please fix capslock and fn always on and no display. Need it asap. Thankyousomuch.
            The admin removed attached files [MOD EDIT] Read the rules,no external links ! ,you`ve already received multiple infractions and been given the link to the rules, try reading them !! the so...
            01-17-2024, 05:29 PM
          • ROONEY50
            Huawei Matebook D14 NBL-WAP9R (DAH98AMBAD0)
            by ROONEY50
            Hi.
            I'm learning about fixing computers and have received a dead Huawei D14. It has a nearly fully charged battery in it (16.5v) but no charger(USB-C). Without the battery connected, these are the ohm readings I'm getting.
            3.3v coil - 25 ohms
            5v coil - OL
            The other 3 coils on the board are showing
            250 ohms
            45.3 ohms
            4000 mega ohms
            I'm assuming the 3v is shorted maybe?
            When I power the laptop on, it shows as dead. No CPU heat, no picture and no fan. However I noticed the 3.3v and 5v coils are showing the right...
            10-10-2025, 12:56 PM
          • DrFalken
            Huawei Magicbook m/b DAH98AMBAD0, dead
            by DrFalken
            Just arrived a Magicbook with m/b DAH98AMBAD0 completely dead, power LED stay OFF.
            Checking with thermal camera I see a chip labeled 4GA "pulsating".
            4GA code point me to "FT521GAb"="LDO, Dual out, Vout1/Vout2=2.8V/1.2V±2%, 250mA, +CE"
            Maybe something is shorting it ?
            What can I check ?
            Can't find it on the attached schematics - https://www.badcaps.net/forum/troubl...atebook-no-cha...
            03-30-2023, 02:58 AM
