Need help cleaing BIOS ASUS ROG GU501
  • vexarvf1s
    • Aug 2022
    • 23
    Need help cleaning the ME area and verifying that this BIOS is in a healthy state.
    I was going to try and follow the guide from https://winraid.level1techs.com, but it seams that the image for CS ME12v33 is corupted.
    Computer is an ASUS ROG GU501GM-BI&N8, SNJCNRCV02U691516
    Mainboard is PN: 60NR00F0-MB4280 GU501GM 17652219
    PT: N0CV1849MB0031295 69N14LM21F04(01)
    I am attaching the BIOS file with the product key masked out.
  • vexarvf1s
    • Aug 2022
    • 23
    Additional info. After attempting BIOS update from Windows the computer failed to reboot screen went black. Computer will turn on, Power LED, Charging LED, but will not load windows. No display on LCD nor on external monitor. System powers up, but the computer seems to stop after accessing the hard drive. Letting it sit 30 to 60 min. has not resolve the issue. Tried BIOS recovery via ASUS.ROM, AMIBOOT.BIN, AMIBOOT.BIN and ctrl + HOME does ping the USB flashdrive, but no change.
    • volinakis
      • Jan 2021
      • 2748
      • N/A
      what's the point of masking win key since it is registered to microsoft servers? Think, it's for free!
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • lrouw84
        by lrouw84
        Hi there,
        01-28-2023, 01:31 PM
