Asus GL502VMK BIOS Lock
  • lordrussell
    • May 2015
    • 31
    Hey Gurus
    Kinda as the title says, some dufus managed to drop a password in said bios & I'm running around in circles to clear it. FWIW, I've included the 8MB - 64MB & Asus' support site bios-zzzz. Seeing as I'm not a code guy in the slightest, I could sure use the help.
    I thank all you MENSA Society members upfront for your help in my silliness.
    Asus GL502V (but the board has GL502VMK silk screened on it, ssssoooo...?)[model numbger bellow the scan=tag = GL502VM-BI7N10 {insert my confused face}
    S# - H3N0CV014552093
  • peste
    • 13441
    • ROMANIA
    Originally posted by lordrussell
    Hey Gurus
    try...
    admin password KaelAngelus1
    boot password PrincessRori1
    • lordrussell
      • May 2015
      • 31
      Thank you immensely peste! I will get right on it & let you know if this works out.
      You're the best!
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • ArtMov
        [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
        by ArtMov
        Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
        1. I made overclocking lock disabled the default in amibcp
        2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
        03-31-2023, 01:30 PM
