Add chip support to EZP2019, EZP2019+, EZP2020, EZP2023, EZP2025, MinPro Programmers
    • 22157
    This is a Github project, i have not used this software as i don`t own any of these programmers.The software looks good though,so i might just
    have to buy one,you can never have enough programmers
    QT based editor chip database for EZP2019, EZP2019+, EZP2020, EZP2023, EZP2025, MinPro programmer devices.
    For linux:
    https://github.com/bigbigmdm/EZP2019...ip_data_editor
    Authors homepage where there`s a windows version -> https://antenna-dvb-t2.ru/EZP_programmers.php
  • quadri234
    • Apr 2017
    • 12
    • nigeria
    I bought ezp2025 version but I was not able to use it because I can't find the software to install it, pls help if you have
  • quadri234
    • Apr 2017
    • 12
    • nigeria
    Ezp2023 software is not working for the 2025 version and the softwares provided on their website is corrupted
    • Wotthefaq
      • Mar 2025
      Quadri234 i believe you need to install the proper WinRAR program or will say corrupted
      • quadri234
        • Apr 2017
        • 12
        • nigeria
        Corrupted
        • jozlar
          • Mar 2022
          • 59
          • tbilisi
          Hello, I have ezp2025 and I can't see the corresponding program. I also have ezp 2019 but it doesn't work on it.
          • quadri234
            • Apr 2017
            • 12
            • nigeria
            2019 software will not work for 2025 version
              • 22157
              This thread is only about a software project for adding chip support, it has nothing to do with the software that the programmer comes with. You should contact the seller and ask them for working 2025 version software.
              • donato2022
                • Aug 2022
                • la paz
                aca esta gente el software para el epz2025
                Here are the people who provide the software for the EPZ2025.
                in English please..
                • quadri234
                  • Apr 2017
                  • 12
                  • nigeria
                  in English please..
                  Did you confirm if this software is working perfectly for ezp2025 version
                  • ToNe 36
                    • Mar 2025
                    • 6
                    • Romania
                    EZP2025 works but you have to tweak it around ad i did there... You have to use locale editor I sent email to the producer hope he will fix it
                    • quadri234
                      • Apr 2017
                      • 12
                      • nigeria
                      Thanks for this, I really appreciate, I will try this and report back
                      • quadri234
                        • Apr 2017
                        • 12
                        • nigeria
                        Thanks pal the locale editor work the magic, thanks once again
                        • ToNe 36
                          • Mar 2025
                          • 6
                          • Romania
                          here you can find updated version fixed by the developer which he has sent me...no need for locale emulator
                          Last edited by SMDFlea; 06-21-2025, 01:04 PM. Reason: added attachment from external link
                          • quadri234
                            • Apr 2017
                            • 12
                            • nigeria
                            Thanks for sharing
                            • SingleCore
                              • Jun 2025
                              • 3
                              i have tested the programm. it crash after startung without any log or error messages.
                              system: win 11 24H2, Pro with all latest updates
                                • 22157
                                Which program do you mean
                                • SingleCore
                                  • Jun 2025
                                  • 3
                                  this one is bugged. i redownloaded it just 5 minutes ago and it crash on start. it throw neiter messages or errors also not produce a log. so i cant tell more.
                                  there is a debug mode for check ?
                                  • rockman97
                                    • Aug 2025
                                    • 10
                                    • Hungary
                                    I had my old motherboard i really want build a HTPC and i want use this mobo but i tried BIOS update in 2024 and the motherboard is cooked it get orange led only tried change cpu ram everything but can't fixit. (I bought the motherabord second hand in 2023.)
                                    It has a Winbond 25Q256JWEQ (I think this is a 1.8V model so i used the 1.8v adapter aswell.) Bios chip on it i tried reflash with my EZP2019+ programmer but when i manually choose a chip like similar to this i click the read button and only shows 000 and i can erase it when i try write i can't verify it.
                                    I have a clip and i want use this i can't solder the chip.
                                    Which chip is similar to this Winbond chip or how can i fix this?
                                    Can i flash this type of chip with this programmer and how?
                                    I have a BIOS file from ASUS Website.
                                    I asked this another post but somebody linked this thread
                                    Thanks for the help.
                                    • m1ch43lzm
                                      • Mar 2019
                                      • 1066
                                      • Peru
                                      rockman97
                                      I'll attach the EZP2019+ software for you, downloaded from site linked at 1st post, I don't own this programmer
                                      The W25Q256FW is listed, it should be compatible, you have to use 1.8V adapter
                                      • Troystain
                                        Help EZP2023+ updated chip database for w25q256jveq?
                                        by Troystain
                                        Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                                        I need to add w25q256jveq chip but I do not know what data should I type.
                                        I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                                        The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                                        11-25-2024, 12:53 AM
                                      • sume
                                        bios chip can not detected on ezp
                                        by sume
                                        I'm having trouble writing the BIOS to an mXIC MX77U25650F chip using both the EZP2019+ and EZP2023+ programmers. I have tried various connections, but I'm still encountering the same issue. The chip itself is kind of hard to solder. I am using SOP16/8-DIP8 REV4 Board Adapter because it is the only suitable one. How can i fix this issue. The motherboard it belong to is HE430HE530 NM-D481 Rev1.0. And the laptop is Lenovo thinkpad e15 gen3. I fixed many bios chips, but this one is very different.
                                        05-03-2025, 04:34 AM
                                      • ToNe 36
                                        EZP2025 Working english program
                                        by ToNe 36
                                        Hello from Romania here I present you the working EZP2025 without using locale editor sent to me by the developer.
                                        It works without having to tweak it with locale emulator..
                                        I sent mails to the developer and he was kind enough to send me the fixed version which is not having the richedit error....
                                        Please save it and share it on other forums as well as the chinese man said he can not upload it on his website....strange....
                                        EZP 2025 works only with this version so it will not work with older versions..........
                                        06-21-2025, 01:32 PM
                                      • pengamat_hebat
                                        Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
                                        by pengamat_hebat
                                        I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
                                        Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
                                        However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
                                        I also tried applying 3.3V to pin 3, but it still didn't work.
                                        I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
                                        03-25-2025, 04:13 AM
                                      • redbaron1007
                                        Looking for a way to read this bios chip. Lenovo Yoga 7 16arp8 bios chip.
                                        by redbaron1007
                                        I'm working on a lenovo yoga 7 16arp8 that had a bad charge port. When I replaced the port the laptops charge light will come on and stay on now, but when I push the power button the power light will come on for a couple seconds and then go right back out. I'm suspecting a bad bios, but when I went to read the bios to start the process of getting a new one it I found that none of my programmers will read the IC. I mainly use a T48 with Xgpro. I also have a ch341 and it's software that I use for ps5 uart and bios's, and a EZP2019+ and it's software.
                                        The chip is labeled MXIC MX77u2565ofz4142...
                                        10-02-2025, 12:51 PM
