ASUS VIVIBOOK X541UV BIOS password removal is possible!
  • Yacine007
    • May 2024
    • 92
    • Maroc
    Could someone assist in removing the BIOS password from this binf file? I've tried and failed to follow the guides regarding AMITSE decryption !
    Laptop is an ASUS X541UV - bin file and pictures attached.
    Thanks for reading!​
    • 21692
    Type the serial number please..
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Yacine007
      • May 2024
      • 92
      • Maroc
      SN : G9N0CV178677393
      • hoaca388
        Badcaps
        • Jan 2022
        • 12281
        Try and feedback
        • Yacine007
          • May 2024
          • 92
          • Maroc
          This is my first request and I am very grateful, thank you very much it works very well everything works correctly.
          • Yacine007
            • May 2024
            • 92
            • Maroc
            Originally posted by hoaca388
            Try and feedback
            Hello my friend hope you're fine, well after testing everything i have a problem with the fan it turn very high 2400rpm in normal condition.
            Is there a program to control the fan? Or it's a problem with the bios version! Thank you in advance
            • hoaca388
              Badcaps
              • Jan 2022
              • 12281
              F541UV
              • Yacine007
                • May 2024
                • 92
                • Maroc
                F541UV
                Thank you very much for your intention and cooperation 🙏 apparently it's a manufacturer defect, it works like that. Thank a lot my friend may god protect you.
                • Mobilguru
                  • Oct 2021
                  • 5
                  • Hungary
                  Hi!
                  I've got an Asus X541 UV which asks for password when it turns on.
                  The Alt+R method doesn't work...
                  Can someone unlock this for me?
                  The board shows:
                  Asus X541UVK MAIN BOARD
                  REV. 2.0
                  I've Attached the bios dump!
                  Thank you!
                  Regards:
                  Daniel
                    • 21692
                    Originally posted by Mobilguru
                    Hi!
                    The board shows:
                    REV. 2.0
                    Thank you!
                    Regards:
                    Daniel
                    Please read the rules, type and post the laptop serial number -> https://www.badcaps.net/forum/troubl...before-posting
                    • Mobilguru
                      • Oct 2021
                      • 5
                      • Hungary
                      Sorry! SN inclueded!
                      Serial: J1N0CX041958018
                      • Blaze Tech
                        Learner
                        • 214
                        • Ghana
                        Serial: J1N0CX041958018​
                        TRY
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12281
                          Try : Mandarin2025
                          • Mobilguru
                            • Oct 2021
                            • 5
                            • Hungary
                            Originally posted by Blaze Tech
                            TRY
                            Thank You!
                            • Dagger360
                              • Aug 2025
                              • Namibia
                              Hello all, I have a Asus X541N with BIOS Administrator password lock.
                              Tried everything, searched threads and opened the PC to take it apart and remove battery but nothing worked.
                              Hopefully someone can help me, thank you.
                              Relevant info:
                              Asus X541N
                              SN: J1N0GR01W33302C
                              BIOS Version: 314
                              Thank you again.
                              • peste
                                • Dec 2016
                                • 13451
                                • ROMANIA
                                Relevant info:
                                Asus X541N
                                SN: J1N0GR01W33302C
                                BIOS Version: 314
                                Thank you again.
                                post the contents of the bios chip even if it is corrupted..
                                The bios chip must be unsoldered from the board before writing or reading..
                                do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                solder wires between the programmer and the bios chip..
                                you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                • Dagger360
                                  • Aug 2025
                                  • Namibia
                                  Thank you for responding. I managed to remove the BIOS admin password by following these steps:
                                  I opened the laptop and removed the battery causing the date and time to reset to 2019-9-16.
                                  I then booted up the PC and it asked for BIOS password and I inputted a wrong password once and pressed enter to clear wrong password message and then pressed alt + r to switch to recovery code page. The page displays the reset date which you have to subtract by ten years and look for corresponding code on this webpage: https://***********/threads/master-p...oogle_vignette
                                  So if PC shows 2019-9-16, you would subtract 10 years which is 2009-9-16; meaning the code for 2019-9-16 is ALAO1AD1.
                                  I entered the code and it cleared the admin pin
                                  The whole reason I found myself in this situation is because the PC would only boot into BIOS asking for pin.
                                  Turns out BIOS did not want to boot MBR formatted hard drives so I reformatted the internal drive to gpt UEFI: NTFS and installed clean windows and it worked. Everything running perfectly.
                                  Hopefully this message helps someone else someday
                                  Thank you again for responding.
                                  • razor_amd
                                    by razor_amd
                                    12-15-2020, 07:07 PM
                                  • grimacelord
                                    by grimacelord
                                    07-10-2025, 02:52 PM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • lucaszmn
                                    by lucaszmn
                                    Problem:
                                    Initial Findings:
                                    • I concluded that the
                                    08-12-2025, 03:01 PM
                                  • davidebeatrici
                                    Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
                                    by davidebeatrici
                                    I had 3 people contact me in a week because Windows suddenly didn't boot:
                                    As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
                                    The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
                                    Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
                                    06-17-2025, 12:59 PM
