Need BIOS for ASUS TUF FX506 FX506**
  • stikerun12
    electronics
    • Nov 2022
    • 38
    • Bucharest
    #41
    Alo the windows loading screen with asus Logo it`s take too much and the caps it`s not responding, but if i wait a few minutes, the windows is starting and everything is normal, benchmark, game, no issue.
    The memory stick was switched with another 100% good and no effect.
    • m1ch43lzm
      • Mar 2019
      • 1125
      • Peru
      #42
      Try, this has DMI added
      FX506HC-F1.300 stikerun12.rar
      If it works update with EZ Flash to 311
      https://www.asus.com/laptops/for-gam...TUF-Gaming-F15
      Also attached clean BIOS
      FX506HC-F1.rar
      • stikerun12
        electronics
        • Nov 2022
        • 38
        • Bucharest
        #43
        both bios give Asus logo, reboot and after that it`ts getting stuck forever
        I tried first with original EC and secound with clean EC, nothing..
        • m1ch43lzm
          • Mar 2019
          • 1125
          • Peru
          #44
          So you can't even enter BIOS setup with the files I gave you... That was the idea, enter BIOS setup, then to EZ Flash to update to latest version from USB
          First, try removing the SSD, check if you can enter BIOS, if yes, update to 311 using EZ Flash, load setup defaults, save and exit, power off
          Install SSD, then check if Windows boots
          If that doesn't work, try "test1", it's the same ME region as the F1 BIOS, but replaced BIOS region from 311
          "test2" is the "polpabs" BIOS, but clean ME and clean BIOS region 311
          As I found another BIOS but is for FX506HCB, don't know if it'll work for you, as you have FX506HC
          I can try stitching the ME region from that one, and the BIOS region from ASUS website update for FX506HC, that is "test3"
          DMI inserted on all "test" BIOSes
          Also attached the FX506HCB clean BIOS 310, if someone needs it
          • stikerun12
            electronics
            • Nov 2022
            • 38
            • Bucharest
            #45
            all 3 bios not working, i ll let this laptop like this, have just bad starting, when it starts working with not problem, strange thing anyway..
            the attached bios is the only bios that working for me with hard start
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
