Need BIOS for ASUS TUF FX506 FX506**
  • jordandeguzman08
    • Apr 2025
    • 4
    • Philippines
    Sorry wrong serial number from previous one - Hi please help me provide a bios bin, no display. thanks
    Model: ASUS TUF FX506LI
    Board model: DABKXDMB8E0 REV.:E
    SN:LANRCX04H086443​
    • hoaca388
      Badcaps
      • Jan 2022
      • 12118
      SN:LANRCX04H086443​
      FX506LI
      • jordandeguzman08
        • Apr 2025
        • 4
        • Philippines
        Hi please help me provide a bios with disabled secure boot and enabled legacy. thanks
        SN:LANRCX04H086443​
        • hoaca388
          Badcaps
          • Jan 2022
          • 12118
          SN:LANRCX04H086443​
          FX506LI
          • jordandeguzman08
            • Apr 2025
            • 4
            • Philippines
            Sorry, I have no idea about that- One more thing - Can you clear TPM and disable it too? Thank you.
            • saklapbhe
              • Nov 2018
              • philippines
              #26
              hi any bios bin for this
              asus fx506hc
              Model: ASUS TUF FX506hc-hn083w
              Board model: DA0NJJMBAGO REV:G
              • peste
                • Dec 2016
                • 13199
                • ROMANIA
                #27
                asus fx506hc
                post S/N, etc.
                post the contents of the bios chip even if it is corrupted..
                • stikerun12
                  electronics
                  • Nov 2022
                  • 15
                  • Bucharest
                  #28
                  HI! Please remove password from this bios. My laptop is turning on but have password on bios.
                  Model: FX506HC-HN004
                  SN: NANRCX00322540B
                  Mobo: DANJJMB1AA0 REV G
                  Intel 11400H and RTX3050 4gb
                    • 21464
                    SN: NANRCX00322540B
                    Password:
                    polpabs
                    polpabs
                    • stikerun12
                      electronics
                      • Nov 2022
                      • 15
                      • Bucharest
                      #30
                      The password is working, but i think this is not the original bios from the laptop. The RTX3050 is not seen (it have all voltages, good bios) and no any ssd nvme bootable device, the usb is working. I attached that bios that i think it is from this mobo, but have no display. The EC is sure from this motherboard. Can you repair this bios please?
                      also i tried to update bios with EZflash, and it say fail to update..
                        • 21464
                        It`s going from bad to worse, first it has a password, now it`s the wrong bios. Scan the QR code on the motherboard and post what it says.
                        • stikerun12
                          electronics
                          • Nov 2022
                          • 15
                          • Bucharest
                          #32
                          this is the mobo, the ec seems to be original, was not wire connected before as i see., but the bios was changed or modified, i don”t know
                          The password bios was from here(post #9), the last attached is from laptop, but seems to be changed or modified, i don”t know. But i have no screen with original.
                            • 21464
                            Scan the QR code and post what it says. If you can`t scan it post a good clear picture of it instead ,not some blurry crap, then we might be able to scan it or see if it has a model number written around the edge.
                            • stikerun12
                              electronics
                              • Nov 2022
                              • 15
                              • Bucharest
                              #34
                              This is what is say: QCCNJJ7AZ23804148,N938NRCX00BZ7TMB,FX506HC,60NR0720-MB2005,140,A036BC303613
                              • stikerun12
                                electronics
                                • Nov 2022
                                • 15
                                • Bucharest
                                #35
                                That lock bios with password is from here. (post #9). The last one updated is from laptop, should be original, but i see marks around cip, probably someone has tried to reflash, and i don”t know if it is original or not..
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12118
                                  #36
                                  FX506HC non DMI
                                    • 21464
                                    If the bios above doesn`t see the SSD try this one. DMI added.
                                    • stikerun12
                                      electronics
                                      • Nov 2022
                                      • 15
                                      • Bucharest
                                      #38
                                      both bios do not show image. The only bios that enter in bios and not showing GPU, ssd and now i see it can”t boot from usb either is locked one with password polpabs. I think it can be a problem from cpu, solder balls cracked or sth, is very strage. You have another solution/sugestion?
                                      In the photo is that bios that was lock with password, is the only bios that give me imagine.
                                        • 21464
                                        try this one.
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
