Hp Probook 440 G10 Bios Needed
  • geraldkacka
    • May 2021
    • 21
    • United Kingdom
    #81
    it worked but i lost my dmi info
    • rex98
      • Feb 2023
      • 1296
      • Mandaue CEBU, Philippines
      #82
      use my tool https://www.badcaps.net/forum/troubl...57-hp-dmi-tool
      • Deba Modok
        • Aug 2023
        • 22
        • Bangladesh
        #83
        Please help me , my hp 440 g10 laptop no display
        board part number : da0x8tmb8e1 rev e
        • peste
          peste commented
          Editing a comment
          post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
      • peste
        • Dec 2016
        • 13759
        • ROMANIA
        #84
        post S/N,product number,etc.
        • Deba Modok
          • Aug 2023
          • 22
          • Bangladesh
          #85
          S/N: 5CD4396VQM
          product id: 967U0ET#BH5
          laptop model: hp probook 440 g10
          • videiro chiconela
            • May 2023
            • 7
            • mocambique
            #86
            Need Bios File for this model
            Hp Pro Book 440 G10
            Mbd Part Number : DAOX8TMBE1 REV. E
            Cpu Number : SRMLX
            S/N: 5CD3445650
            Main + Ec Need 32mb both
            Bios Tempered No Display Fan Snining Max
            • Ariel Arrizabalaga
              tech
              • May 2024
              • 19
              • España
              #87
              Can you help me with my HP PROBOOK 440 G10 with BIOS password? Greetings and thank you very much.
              Marca: HP PROBOOK
              Modelo: 440 G10
              Numero de Serie: 5CD332D4NK
              Product ID: 816C4EA
                • 22119
                S/N: 5CD4396VQM
                Flash both bios from this post - https://www.badcaps.net/forum/troubl...58#post3665458
                Get the DMI info from your backup using rex98`s DMI tool - https://www.badcaps.net/forum/troubl...57-hp-dmi-tool
                Fill in your DMI with HP Bios Config Utility - https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
                  • 22119
                  Hp Pro Book 440 G10
                  Cpu Number : SRMLX
                  S/N: 5CD3445650
                  Get the DMI info from the stickers on the laptop
                    • 22119
                    Marca: HP PROBOOK
                    Modelo: 440 G10
                    Product ID: 816C4EA
                      tech
                      • May 2024
                      • 19
                      • España
                      #91
                      Can you help me? I'm not able to inject the extracted DMI into the clean BIOS.
                      • volinakis
                        • Jan 2021
                        • 2875
                        • N/A
                        #92
                        "Fill in your DMI with HP Bios Config Utility" - install BCU, use cmd as admin, cd (change directory) where BCU was installed and use cmd line " biosconfigutility /get:1.txt
                        Open 1.txt and fill empty fields with extracted DMI, save file as 2.txt (in Docs, then move it in BCU folder) then use cmd line " biosconfigutility /set:2.txt
                          tech
                          • May 2024
                          • 19
                          • España
                          #93
                          Thanks, I've solved everything and it's working perfectly.
                          • essaadi
                            • May 2016
                            • 52
                            • MOROCCO
                            #94
                            Can you clear BIOS password please.
                            Product : HP PROBOOK 440 G10
                            S.N : 5CD4023JD5
                            Thank you very much
                              • 22119
                              S.N : 5CD4023JD5
                              Thank you very much
                              • essaadi
                                • May 2016
                                • 52
                                • MOROCCO
                                #96
                                thank you very mach... I will try this solution even if DMI TOOL didnt work for me.
                                • best49
                                  • Sep 2025
                                  • FRANCE
                                  #97
                                  Hi,I need bios hp Probook 440 g10
                                  ns: 5CD42374JG
                                  • peste
                                    • Dec 2016
                                    • 13759
                                    • ROMANIA
                                    #98
                                    ns: 5CD42374JG
                                    post S/N, full name and model, motherboard model, product number,etc.
                                    post the contents of the bios chip even if it is corrupted..​
                                    • best49
                                      • Sep 2025
                                      • FRANCE
                                      #99
                                      • peste
                                        • Dec 2016
                                        • 13759
                                        • ROMANIA
                                        #100
                                        Don't post pictures unless asked...
                                        The bios chip must be unsoldered from the board before writing or reading..
                                        do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                        solder wires between the programmer and the bios chip..
                                        you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
