Hello guys! I am facing an issue with a dell alienware m17 r5, with service tag h2c08r3 . i got no display.
dell alienware m17 r5 bios
Alienware m17 R5 AMD
Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donate -
Requesting a clean bios for an Alienware M17 R5 board LA-L656P. The laptop turns on but does not post. If I remove the ram I get an power led error code which makes me believe that the bios is doing something. Any help would be appreciated. I have attached the original dump of the bios chip. Thanks!Attached Filesif you find these attachements useful please consider making a small donation to the site
Thread merged. Please post the laptop service tag --> https://www.badcaps.net/forum/troubl...before-postingRequesting a clean bios for an Alienware M17 R5 board LA-L656P. The laptop turns on but does not post. If I remove the ram I get an power led error code which makes me believe that the bios is doing something. Any help would be appreciated. I have attached the original dump of the bios chip. Thanks!
Every donation made will go towards server fees and maintenance costs.Comment
thank you for response.
I want to upgrade from 3070ti to 3080ti and i need VBIOS for 3080TI.
Board:
HDQ53 LA-L761P rev. 1.0
I don't have SN because the laptop was bought as an demonstration model.
Thank you.
M.Comment
Or please direct me where I can find the bios. Thank you
Thank you.Comment
Stop working after Windows Update overnight, need new or fixed BIOS for Alienware M17 R5 AMD
Reg Model: P50E
Reg Type: P50E002
Service Tag: 4JZ1YR3
EX:9914864943
MB Rev: HDQ53 LA-F761P Rev:1.0 (A00)
Also not 100% sure which is the BIOS chip FM25Q08B or W25R256JVEIQ, Read with CH341A MF: Hudan Part# FM25Q32, did 4MB, 8MB and 32MB read all came back with all FFF...Attached Filesif you find these attachements useful please consider making a small donation to the site
W25R256JVEIQ↵
https://www.badcaps.net/donateComment
Thank you for the correction, here is the read on W25Q256JV Bios ChipStop working after Windows Update overnight, need new or fixed BIOS for Alienware M17 R5 AMD
Reg Model: P50E
Reg Type: P50E002
EX:9914864943
Service Tag: 4JZ1YR3Attached Filesif you find these attachements useful please consider making a small donation to the site
were same bro, my unit not turning on after forcing shutdown while bios update, did you find good bios?Stop working after Windows Update overnight, need new or fixed BIOS for Alienware M17 R5 AMD
Reg Model: P50E
Reg Type: P50E002
EX:9914864943
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
- Loading...
